914Sixer
Sep 3 2005, 07:36 PM
What is the Bosch part number for the 914-6 fuel pump? Is it 0580463005 or GFP 252? I want to make sure before I buy it. I have the 911 number but I think I remeber the the 6 number ends in 005. Thanks, Mark.
North Bay 914
Sep 3 2005, 09:12 PM
The box my 914-6 pump came in has all the numbers you listed, but the pump housing has a different number.
0.580.960.009
When I was trying to verify this was indeed a 914-6 pump I went thru some difficulty verifing this was the correct one. It has the regulator block on it so I assume it is correct. I have not checked it yet to see if it indeed makes 3.5 PSI when running. I am told it is the best pump for carbs by a very reputable source.
smg914
Sep 3 2005, 10:53 PM
I replaced the fuel pump in my 914-6 back in 1999 and the part number is 580.960.009
BigD9146gt
Sep 5 2005, 04:49 PM
The part number is also going to be the same as any early '70s 911T...(pre CIS)
