URY914
Sep 4 2005, 07:25 AM
I had always used Gunk engine cleaner and hated the smell of that crap. I read here about guys using EZ-Off oven Cleaner and it's lemony fresh smell. It not only smells good but it works better. I sprayed it on about 4 times until the can was gone. Hosed it off between applications. No oily film left over. It also seems to etch the aluminum to give it a sorta dull finish.
I give it two thumbs up.
URY914
Sep 4 2005, 07:26 AM
It also takes off the paint over spray.
Can I use it on my dogs?
TimT
Sep 4 2005, 07:30 AM
now you just have to get some oil on the tranny so the case doesnt oxidize
scottb
Sep 4 2005, 07:40 AM
if i recall, ez-off has lye in it which eats aluminum. sure looks nice but i don't know if i would want something to eat away at my case. just my $.02.....
jim_hoyland
Sep 4 2005, 07:43 AM
Can the case be powder coated without affecting it's cooling ability ?
I saw several tranny cases being powder coated at a local place; however, I've been told by other 914 owner that our cases cannot be coated.
Any feedback will be appreciated
URY914
Sep 4 2005, 08:12 AM
QUOTE (scottb @ Sep 4 2005, 05:40 AM) |
if i recall, ez-off has lye in it which eats aluminum. sure looks nice but i don't know if i would want something to eat away at my case. just my $.02..... |
Washing it off with the hose should take care of that.
Allan
Sep 4 2005, 08:15 AM
So the 901 tranny case is not magnesium?
bd1308
Sep 4 2005, 08:18 AM
the tranny's are magnesium....
left uncoated, little speckles will form all over the tranny case....I witnessed this when I did my engine swap....
i dunno what people use to coat thier tranny's in though.
rhodyguy
Sep 4 2005, 08:20 AM
if you've seen the movie "Fight Club", you would know that vinegar neutralizes the caustic nature of lye. i used Oil Eater on my trans yesterday. it worked well also.
k
bd1308
Sep 4 2005, 08:21 AM
I've seen that scene....
it looked real bad.
morph
Sep 4 2005, 08:30 AM
yep oven cleaner works awsome.I use it all the time.
james
J P Stein
Sep 4 2005, 08:54 AM
It will also take anodize off wheels...+ some scotch brite.
Trekkor
Sep 4 2005, 11:30 AM
mine after GUNK and water.
KT
sean_v8_914
Sep 4 2005, 11:56 AM
99c store imitation easy off did not work well. I sprayed mine w wd40 when I was done. this keeps teh white fuzz from growing
pete-stevers
Sep 4 2005, 12:02 PM
The reccomendation is not to paint?
thats to bad....and wire polishing is a waste as well due to the oxidization afactor??
any painted boxes out there?
Porsche Rescue
Sep 4 2005, 01:33 PM
This one is painted silver. I got it that way. Has chipped here and there but overall paint is sticking pretty good. I was taking pic of engine so not the best shot of the tranny.
Katmanken
Sep 4 2005, 02:06 PM
I'd mix up some baking soda and water and spray that tranny after the oven cleaner. Baking soda neutralizes BOTH acids and bases to a neutral PH. Mag can corrode faster than you can believe.
I keep boxes of baking soda in the garage to use for a lot of things.
Painted my tranny with a zinc chromate primer as the zinc is more reactive than the mag and is a recommended sacrificial coating for the mag. Thin coat of silver paint on it too.
Ken
SLITS
Sep 4 2005, 04:34 PM
Mine was painted blue.....
I believe that Zinc/Chromate based coatings were banned or severly restricted in the "Tree Hugger States". Only the Feds are allowed to use it.
redshift
Sep 4 2005, 04:46 PM
There is a creme, it's a facial grade creme, made in Iowa, in the valley of the jolly green giant, in a little hollow tree.
Living in this tree are a family of elves, the Keeblers. These elves are connected (by mandate of house resolution S-4559) to machines, that pump their essence out.
That elven creme can be used to prevent scaling on magnesium.
M
eric914
Sep 4 2005, 06:27 PM
Zinc Chromate Primer is available from aircraft supply stores. Try
Aircraft spruce
