Congrats Trekkor.
Is that Mr. Bunch?
Does RR have their own timing trailer. If so make sure you find out about the logistics of getting it to the events. Will you be responsible for towing?
Also, do you need to procure AX sites other than the airport?
What about results?
Not trying to dissuade you, just want to make sure you understand everything that is involved. ( at least these are duties in GGR and LPR)
It is great to be in charge, gives you a chance to massage operations into the way you would like to see them.
Also helps when you have great friends and volunteers to help out.
Conflicts in schedule should not be an issue since the Zone 7 calander is set up early in the year, if not before. Your AX dates should not conflict with SVR or GGR DEs or TTs.
