DanT
Sep 5 2005, 09:20 PM
Wanting to get some Ideas of where and how folks ran their lines to their front mounted coolers.
Have decided that the front is the place to be. So need some input as to what you folks have done.
Pics or links to threads would be appreciated.
thanks
Aaron Cox
Sep 5 2005, 09:23 PM
ok. 2 ways to get to the front. throught the heater tube in the long, or under the rockers like factory GT cars.
ive got lots of pics... here you go.
Aaron Cox
Sep 5 2005, 09:24 PM
more up the rocker...
Aaron Cox
through the hole....
Aaron Cox
Sep 5 2005, 09:26 PM
Aaron Cox
Sep 5 2005, 09:27 PM
or... up the heater tube..... (benmartins install)
Aaron Cox
Sep 5 2005, 09:28 PM
mo
Aaron Cox
mo
Aaron Cox
Sep 5 2005, 09:29 PM
once they go through the box on either of driver or pass foot wells....
Aaron Cox
again....
Aaron Cox
Sep 5 2005, 09:31 PM
cant find the drivers side pics
Aaron Cox
Sep 5 2005, 09:32 PM
anyquestions????
J P Stein
Sep 5 2005, 09:49 PM
or thru the heater tube, out the long, thru the bulkhead, over the rack & out vent holes.
Pics:
J P Stein
Sep 5 2005, 09:55 PM
bla bla
J P Stein
Sep 5 2005, 09:57 PM
bla bla bla
xitspd
Sep 5 2005, 10:00 PM
This line hooks to that line and so on and so on!
McMark
Sep 5 2005, 11:52 PM
I recently pondered the idea that you might be able to fit a AN-10 or similarly sized line inside the long next to the heater tube.
Aaron Cox
Sep 5 2005, 11:54 PM
QUOTE (McMark @ Sep 5 2005, 10:52 PM) |
I recently pondered the idea that you might be able to fit a AN-10 or similarly sized line inside the long next to the heater tube. |
heater muffler is pretty beefy..... how do you get em in?
McMark
Sep 5 2005, 11:55 PM
Same way you did. The way I complained about.
The heater muffler isn't any bigger than those C shaped clips.
Aaron Cox
Sep 5 2005, 11:58 PM
QUOTE (McMark @ Sep 5 2005, 10:55 PM) |
The heater muffler isn't any bigger than those C shaped clips. |
hmmm. neat idea. been a while since i saw the heater mufflers on a shelf somewhere....
BTW - Ive got reinforcement plates to weld in on each side of the opening
McMark
Sep 5 2005, 11:59 PM
Actually, in the upper left corner of of that picture might be better. Plenty of room up there.
McMark
Sep 6 2005, 12:01 AM
Yeah, I figured reinforcement plates were the answer. Trying to route the hose basically blindly through the long would be a real test of your patience.
brant
Sep 6 2005, 08:37 AM
Or through the heater tube and up where the stock windshield defroster would be:
