Full Version: Fred's 2374 -> 2258 Engine Build Thread
Pages: 1, 2, 3, 4, 5
zig-n-zag
The “initial mock-up test fit” and “case gauge” comment triggered a memory on how I was told to determine if a case was still good or not.
Say you came across a used Type 4 engine for sale which was complete and still together. Check the 6 case bolts if they are still torqued to factory spec. If they are, then torque those case bolts to 30 ftlbs. The crank should still turn smoothly. Any binding means the case would need a line-bore.
If the nuts were loose, inspect the case saddles. The original machining marks should be visible. If not, then line-bore. Yes, you can check by installing a crank with bearings and do the 30lbs test, and it will probably pass. But if built, when the engine comes up to operating temperature, it may seize.
930cabman
QUOTE(friethmiller @ Jul 17 2026, 01:24 PM) *
Do I have to run the AFR gauge into the main cabin? This cable is thick. Would it be sufficient just run it into the engine bay and put the gauge there? I know it's not a gauge that you don't need all the time. Opinions welcome?
I purchased an Innovate LM 2 several years ago, just recently got it connected successfully (connected into the cabin), it is showing rich under 3k rpms telling me the idle circuit needs to be leaned out. In the past I have relied on the color of spark plugs for AFR. Has worked ok for me, but I am far from a dyed in the wool tuner, more like seat of the pants.
I like having a tube fed oil pressure gauge and a capillary tube temp gauge in the cabin. BUT, my builds are stock, nothing out of the ordinary. I'll bet cylinder head temps are also important
Jack Standz
QUOTE(friethmiller @ Jul 18 2026, 02:24 AM) *
Fred.
Don't see how the gauge does you any good if you can't see it. So, yes in the main cabin where you can take note of AFRs under load, at different RPMs, WOT, going downhill, at cruise, etc. An AFR gauge really helps dial in carbs, idle jets, main jets, air correction, emulsion tubes, pump jets, venturis, etc.
With all the possible combinations of adjustments, it is an iterative process, so you'll want to note how your changes affect the AFRs. Then at some point you say things are "good enough", especially if you regularly run the car at sea level and at altitude. Until then, it's a gauge you're always watching.
friethmiller
Yeah that doesn’t make sense for an AFR. Can’t really see back there while you’re driving. I was looking at the wrong end of the cable and thinking “how in the world am I going to get this huge connector through the firewall". Luckily the other end was much smaller. I’ve already routed it with the CHT wires up under the console. Next, I need to figure out exactly how/where I going to mount the gauges.
friethmiller
Quick Update:
Brothers VW Machine in CA was able to verify and fix the problem. They lightly polish my new crankshaft to provide the correct clearances for my EC case. If you recall, the parting line oil clearances were the issue with this case. I will of course verify things again once it's back in the garage. The case, bearings, and crank will likely return the middle of next week. So, next weekend will be set aside for getting [re]started. cheer.gif
friethmiller
Engine Assembly - Part 1 (8/22/2026):
With the case, crank, and bearings back from Brothers VW Machine, I quickly verified measurements and then completely rewashed the case halves to get ready for assembly. The guys had lightly ground my new crankshaft to provide a bit more oil clearance. I did have an issue with measuring the #2 main but I verified it was just my measurements of the crank journal OD and I verified it with some pastigauge.
With everything cleaned, I set out to slide on the gears and test fit everything into the case. Even with the case torqued, everything felt good, no issues rotating the crank with one hand. I did trade out one of the thrust bearings on the cam. One half was too tight so I swapped it out with a spare. I am running a double thrust for this application, of course.
Click to view attachment Click to view attachment
I then pulled everything back apart and cleaned and installed the rods that were already to go.
Again, the case was reassembled and torqued. This time I proceeded by installing all of the head studs using the permatex thread sealant. Next, I added pistons & cylinders for 1&2 (without rings) and got things ready for degreeing in the cam. The timing wheel I was using wasn't really made for VW engines and I had to remove the air/fan shroud studs to properly "clamp" the wheel with the crank bolt. I also used a short section of a clothes hanger to act as a pointer. Pretty easy to do.
So after watching about 6 different Cam Degreeing videos, I felt like I might actually understand what I had to do and why I was taking these measurements. beer.gif
First step of the process was finding true TDC, which was roughed in by eye and then adjusted by going .050 in either direction to verify my zero (TDC).
With this initial task complete, I then moved over to setting up something to measure intake lift using a installed lifter. To set this up, I cut a piece of 16 gauge sheet metal to allow my magnetic base to clamp down to something. I used the 10mm studs on the side of the case that normally secure the thermostat. The next job to do was to measure max intake lift. And here's where things got off track a bit for me. I was getting lift measurements that were low and I couldn't figure out why initially. It turned out the two small bolts that my base was secured to were not enough to prevent the entire stand from moving during this measurement. I think If I had secured the base using a third bolt somewhere, I probably wouldn't have had the issue. To get past the problem, I simply jammed a box wrench between the base on the engine case to prevent things from moving. Another issue was the reach of the dial gauge. It wasn't long enough to reach far enough into the lifter bore to take any measurements at all. There just too much stuff in the way. I got around this problem by stacking a second lifter in the bore. This worked great for me but I'm sure a longer pointer would be available for purchase for the bore gauge. With all the bandaid fixes deployed, I was finally able to get a measurement of .3895 which is just shy of .390 that, when multiplied by the 1.3 rocker arm ratio matches the targeted .507 of valve lift. cheer.gif
Once you have max valve lift, you can then find your lobe center. This is where I zeroed the dial gauge at max lift and then rotated the cam wheel .050" in either direction taking the degree measurements.
For this I got 145 and 59 degrees. Adding them together, I got 204 degrees and then dividing this number by 2 and got an intake lobe center of 102 degrees. I know that if the number is less than the expected value of 104 degrees, the cam is "advanced" by 2 degrees. I think 2-4 degrees would be ideal for street use and might be good to go here. More measuring coming soon. Cheers! beerchug.gif
seanpaulmc
930cabman
lookin good, have you torqued the case together and checked the crank "feel"
friethmiller
Yeah, the crank feels good/rotates without any binding with the case bolts torqued. I still need to do more cam measurements this morning but will be splitting the case to locktite the cam bolts, insert the o-ringed oil pump, etc. before beginning the process of sealing the case together.
friethmiller
QUOTE(seanpaulmc @ Aug 23 2026, 06:44 AM) *
Wouldn't that be wonderful! idea.gif Let's call it a "long shot", for now.
Ninja
That's just BS!!!!!
Fred only has to do it ONCE!!!!
Not fair!!!!
Looks GREAT!
I'd leave it where it is...
friethmiller
Ok, intake duration measured .05 open at 23 degrees before TDC and closes (0.05) after BDC at 47 degrees. That’s (23+47+180)/2 = 250 degrees of duration. That’s spot on! Exhaust is next.
friethmiller
@Jack Standz, note I’m using a 9inch wheel here. Anything larger would probably get in the way of easily replacing the offset washers on the cam. I’m good with splitting the case again for the oil pump install but with a normal pump you could just install it and move on.
930cabman
I would take my time, check and double check everything
Go Fred go
great project, thanks for posting
friethmiller
Exhaust:
Calculated max lift of .496
Lobe center: 108 degrees
Duration: 262 degrees
That’s an ICL of 105.5 ATDC and an ECL of 103.5 BTDC
LSA = (105.5 + 103.5)/2 =104.5
friethmiller
Building up the Short Block (8/23/2026):
First pic shows the base I made for my dial gauge stand. At 16 gauge, it just wasn't thick enough and it needed a third point to really lock it down and keep it from moving ever so slightly.
Before tearing everything down, I took the opportunity to get a rough sense of the shims I would need to order to set the proper deck height. You can see how a longer 78mm crank pushes the piston above the top of the cylinder. I'm basically plus .065.
With the cam properly degreed, it was time to prep everything for the final install of the case halves. I had to loctite in the cam bolts, test fit the oil pump, insert/index the distributor, lubricate everything that needed oiled, and clean-up mating surfaces. Here's a few photos.
Here's the assembled short block. I did run into a problem with the oil pump. It was already clearanced for the cam bolts but the snout of the pump was actually bottoming out where the drive gear locks into the center of the cam. And it only happened once the pump was torqued. And it locked the cam/crank solid too! Scared the crap out of me. blink.gif Not surprised, though. I've never worked with these special straight cut sprockets before. I work to get this problem solved next. More on this soon.
Jack Standz
QUOTE(friethmiller @ Aug 23 2026, 09:53 PM) *
Hi Fred, thanks for the info and photo. Not sure how large the diameter our degree wheel is, but will check. Think it's a Moroso.
Also, we have a straight cut set of cam gears too for the 2615 project. Because we think the thrust bearings would take a beating using helical cam gears (even though we modified a set). Still wish a larger LSA cam was available, at least as an option. But, since they aren't available, one less decision to make biggrin.gif
We appreciate you for documenting your build and sharing . Thanks!
friethmiller
QUOTE(Jack Standz @ Aug 24 2026, 01:52 PM) *
Sure thing! Please avoid all my missteps and mistakes bootyshake.gif My heads are mod'd pretty good and are running double springs so I'm going with the noisy gears. Stay tuned to how I figure out my clearance issue with the oil pump. The metal must come off from the pump and/or the bolt heads. I've got the bolts in with red loctite now headbang.gif so heating them to 500F to back them out might not be an option. I hope to not have to split the case either. We'll see.
porschetub
QUOTE(friethmiller @ Aug 25 2026, 07:39 AM) *
Great progress, question is the relief cut (vee ) in the driven gear to reduce oil foaming or some reduction in noise ? , don't know much about these conversions but the T1 guys mentioned increased noise ? thanks and good luck .
friethmiller
QUOTE(porschetub @ Aug 25 2026, 01:21 AM) *
... question is the relief cut (vee ) in the driven gear to reduce oil foaming or some reduction in noise ? , don't know much about these conversions but the T1 guys mentioned increased noise ? thanks and good luck .
Had to search it. It does a lot of things to include the items you mentioned.
friethmiller
Oil Pump Clearancing (8/24/2026):
Well to get the clearance necessary I had to remove the cam bolts one at a time using heat to loosen everything up. Didn't have any troubles but I did take it easy. I certainly didn't want to strip out the allen heads.
Each bolt was then mounted securely in the vise and filed down/sanded by hand/cleaned. Next, the washers were sanded to smooth out any imperfections. I had to eliminate anything that might prevent the washers from sitting flush in the gear. The next pic shows a bit of work to the pumps drive gear. I used a black marker to help identify any contact/rub points. I also sanded any rough edges on the gear teeth.
Next two photos show the relief to the back of the pump and the cam bolts. I think ideally the cam gear bolts might need to be counter-sunk into the cam washers. Not sure if this is even possible, though. beerchug.gif
So, after test fitting everything without a gasket and getting everything to clear properly with the pump bolts torqued down, I was finally ready for reassembly. After having to insert/remove this pump about 30 times, I had developed a technique for getting the pump perfectly lined-up to go in with one push. So, I decided to roll the dice and insert the pump with the o-ring. You can see in this pic that I've prep'd the gasket (both sides with Curil-T) and used a little bit of assembly lube on the pump body and gasket. I also applied a little bit of lube to the oil pump bore on the case to help protect the o-ring as it went in. And....... after a few tense moments of making sure of my alignment, I was able to push the pump in place. I'm 99.9% sure that the o-ring is still good and right were it needs to be. biggrin.gif
I also took a pic of the thickness of the pump gasket. It's over .060". I wasn't sure what it might crushed down to after torquing but I was glad to have a little more clearance b/w the pump & gear.
Once the pump was in, I focused on cleaning and preparing the cover. This cover was used before and you can see I had a little interface issue with the previous pump. However, I think I have this pump is a little better prep'd. Again, a very light coat of Curil-T on both sides of the paper gasket. Cover went on, and then finally the nuts/washers with a bunch of thread sealant.
I then tested that the engine rotation was good about 3 times during the torque sequence. blink.gif The final test was good to go. I had full unbinding engine rotation using one hand on the crank's snout bolt. aktion035.gif
friethmiller
Crankshaft End-play (8/25/2026):
I had 7 shims to work with last night. I had to take up most of the .050" that I initially measured without shims - targeting the magical .003 - .005 range. After a few tries I was finally able to get 0.003. It's a consistent .003 - .0035 too.
Moving on... Pistons and Cylinders are next!!
friethmiller
Preparing Pistons & Cylinders (8/27/2026):
In preparing for pistons and cylinders this weekend, I cleaned up the work tables and pulled out all the parts and tools I'll need for this next phase of the build. I also took the opportunity to add the small items to the engine to help get stuff out of the way.
Installed the high and low pressure reliefs, front engine mounts, oil filler tower as well as the oil plug, oil screen, and inspection/taco plate.
Ring End Gap
I've got 96mm cylinders; so that's 3.78". Based on the supplied chart, this would calculate as 3.78" X 0.0045" = 0.017". Can this be right? The difference between the JE and the KB piston gap is pretty substantial, I guess.
Cylinder Wall Gap
I'm also looking at Piston to Cylinder Wall Gap. I got a new battery in the 3-4" micrometer, zero'd it, and then took this initial measurement on one of the pistons. Spec says measure point is 0.5" up from the bottom. More to come on this soon.
Weekend goal is to, at a minimum, have the P&Cs 100% ready to install. The cylinder shims that I ordered from AA should arrive tomorrow so I'm hoping to everything in and ready for heads/value train by late Sunday. We'll see. Cheers! beer.gif
friethmiller
@Ninja et. al.
What about this? AI says looser is safer for air cooled.
Ninja
If you're too tight the Grim Reaper will appear and you will be the recipient of further Type 4 education.
If you're too loose, you will have slightly more blow by and MAY see higher oil consumption.
In this case I would go loose...
Forged pistons would add a little clearance as well in my book.
High RPM race type use would add more...
friethmiller
QUOTE(Ninja @ Aug 27 2026, 06:52 PM) *
Thanks Rick!
I've received enough "Type 4 beat-downs" for two lifetimes. I'll go with the recommended looser gaps, thank you very much. slap.gif
porschetub
QUOTE(friethmiller @ Aug 28 2026, 02:42 PM) *
Thanks Rick!
Great response aktion035.gif lol-2.gif lol-2.gif perhaps my reply would have been less polite,end of the day you know what you are doing besides .
Cheers and keep up the good work .
Jack Standz
Maybe take a look at this post:
https://shoptalkforums.com/viewtopic.php?t=1505
However, Raby has said some conflicting things about ring gap over the years (possibly due to his experience with specific ring manufacturers like Deves or Hastings) and that he generally doesn't like too large a ring gap. Lately it seems he doesn't publish his ring gap recommendations, probably to avoid arguments. But, he's built a lot of type iv motors and backs up what he says with test results.
Would really like to get some GT3RS rings that he has recommended to run in our JE pistons with nickies cylinders (102mm), but they don't fit our custom pistons!
friethmiller
QUOTE(Jack Standz @ Aug 28 2026, 01:39 AM) *
Yeah, this is an older thread but it sounds like he was saying .019, which aligns with AI’s recommendation here. Interesting. I’m moving forward though. Having a set of Nickies would be awesome. Can’t imagine what your big 2.6 motor is going to sound like.
HFC3
I don't feel worthy of even reading your posts, but my appreciation and admiration for you and your fellow engine builders is high! Great job.
friethmiller
Piston to Cylinder Wall Clearance (8/29/2026):
Thought I'd verify the clearance for the pistons before moving any further along with the build. The spec for these 2618 forged pistons calls for a large .0035 to .0040" gap. Surely the 93mm pistons that I had the machine shop bore to 96mm would have pull my pistons off the engine cart and verify proper clearance. NOPE!
After mic'ing all the pistons and taking an I.D. measurement of each of the cylinders (several spots up/down at two different clock directions) the numbers I was getting were between 0.0005" and 0.0000" of clearance! I verified this by taking one of the pistons without rings, turned it upside down and watched it stick in the bore. NOPE! I then sent a text to the machinist, his reply was that he thought he had seen his assistant taking these measurements. This was not the right answer. He said I could send them back and have them check and recut the cylinders. I thought about this for a minute or two and then realized how extremely slow this shop was at doing anything. Nope!
Then it hit me. I've got a perfectly good set of KB stoker pistons sitting on the shelve. So, I pulled them out, cleaned them up, and started taking measurements. These pistons measured smaller than the JE pistons and produced excellent numbers on all my clearance checks. Plus, the KB are hypereutectic and allow for tighter clearances. Below pics show my piston measurements and one of many clearance checks made on each cylinder.
Here's a chart I made of the measurements. These are right in-range for these KB pistons.
So, my decision was to go with the KBs and use the JEs on a different build I plan to do next year. First pic shows a little clean up on any sharp edges before cleaning the pistons again in the ultra-sonic cleaner. Second and third photos show me taking an initial deck height on piston #1. Roughly figured I needed a .060 or .050 shim to get in the .045 - .050 deck height range. Depending on the final number, the engine compression will be between 9:1 to 9:2. So, the only thing holding me up from moving forward is a new set of KB piston rings. More to come soon on this... standby.
friethmiller
Saturday Evening Bonus - Flywheel, Clutch, and Pressure Plate Assembly (8/29/2026):
Working down the to-do list here. With the crank's end-play figured out, I was ready to pull out the shims, cleaned them up, clean the back end of the crank/case area, and prepare everything for final assembly. With the shims back in place, I then installed the rear main seal and added some oil to prevent any burn-up durning startup (pic 1). The second photo is my silly attempt at switching to a new flywheel but this was quickly ruled out. 1) It wasn't balanced with the rest of the assembly; and 2) I checked the end-play and it was too tight (like .0005). So, I smartly reverted back to my original flywheel and verified a .0035 float [again]. I'll leave that new flywheel for another build. happy11.gif
Final photo here shows the flywheel, clutch, and pressure plate all cleaned up and installed. Done! beer3.gif
friethmiller
Initial Oil Cooler Work - Part 1 (8/30/2026):
Quick post on my initial work on installing the Tangerine Racking remote oil cooler kit. I thought I'd start my Sunday morning re-reading the instructions. After a second cup was finished, I was finally ready to do this part of the install.
The first pic shows the two custom studs that were inserted with thread-locker. These work with the original 3rd stud to secure this mounting plate. Note the orange seals and the use of a (provided) spacer for the original stud.
Click to view attachmentClick to view attachment
This plate is what holds on the next part. This aluminum block houses an internal thermostat. This mounts to the plate with two long bolts and another set of recessed orange seals. Final photo shows the assembly completed with the large 10AN inlet/outlet. The other parts of this kit will be installed later.
friethmiller
Prep'n Valve Train and Verifying Deck Height (8/30/2026):
While I wait for new piston rings, thought I'd take some time to clean-up the garage a bit and reorganize things for the coming valve-train work.
I had that Tobari guy do 2 sets of rockers for me several months ago so I figured it might be a good time to pull everything out and get everything ready for install. One set of rockers are 10mm and go to this engine, the other set are 8mm that I pulled off an old 1.7L engine of mine. This smaller set or rockers will like be used for the LE's 2.0L, which will be rebuilt right after this engine is finished. First pic shows the parts getting ready for a round in the hyper-sonic cleaner. The second photo is everything ready [with other parts] for the upper assembly install.
With the extra time I had, I thought it might be worth my while to verify deck height on all my cylinders. Glad I did. Looks like going with the .050" shim. I did note a slightly different deck height b/w the two sides of the engine. The 1 & 2 cylinder side measures at .046 and the 3 & 4 cylinder side is at .048. Not sure if that going to cause any problem. Here are few pics of my engine during this process. The cylinders look good. Everything checks out flat! That's all for today. Hopefully more soon once the rings arrive. Cheers! beerchug.gif
Ninja
You SHOULD tighten up deck height numbers when using the hyper-eutectic KBs.
I'd be hunting .038 to .044.
Will increase compression a tiny bit.
Will increase quench action substantially.
Both effects increase power with zero downsides as long as you don't kiss a head.
Running quench this tight means verifying all 4 cylinders!
Your .002+ numbers look great for the KBs.
I'd ceramic coat those flat tops.
I prefer a true flat-top piston over everything else as long as you can achieve a decent compression ratio and clear the valves.
With your cam I'd CAREFULLY check piston to valve clearance as you will be getting close with those.
Did the JEs have valve cuts in the crowns?
friethmiller
QUOTE(Ninja @ Aug 30 2026, 06:01 PM) *
Yes. They added 0.9 cc to the combustion chamber, too.
With the flat top KBs and a 0.045 - 0.047 deck height, that will put me at 9.2 CR. Getting shims to dial things in seems to be a problem, Rick. If you can @#$! out these off sizes please put them in the mail to me, ASAP biggrin.gif
Ninja
Nope, don't have any shims at all.
I can do the math just fine.
You posted your last post while I was making mine, and I didn't see that you had ALREADY checked all 4 (I wouldn't have said anything).
What you came up with will work fine.
I'd prefer to be a little tighter but it's probably not worth the headache.
The SEVERE lack of good/correct/adjustable Type 4 parts is one of the main reasons I won't be walking this path.
The lack of decent machine shops is another. The one you used is the one I'd count on and it doesn't look workable anymore.
For sure you need to check Piston/valve clearance as that was the limiting factor with a true flat top. Those eyebrows the JEs have are BIGTIME useful. They also make the crown thicker and the overall piston heavier. Those KBs are lightweight pistons.
About two years ago I did research shims, pickings were slim then but looked still doable.
What is possible if you have too much clearance is to have the tops of the jugs flycut the exact correct amount. Once again, you are at the mercy of the machine shop.
This is how I set piston-head clearance on everything else; Deck cut.
On normal water cooled (without multiple head gasket thickness available) going too far means another block or fly cutting pistons.
Forged/cast can be fly cut but hyper cannot without diamond tipped cutters.
If you've got any type of dome/rise in the crown you're screwed on fly cutting pistons.
Fly cutting pistons weakens them too.
The trick is getting the deck cut right.
You are doing it RIGHT! You are making the right choices and trying to buy the right parts. I'm not seeing any corner cutting. You are kicking ass!
The really sad thing is that after doing this whole dance spending all this money you will be lucky if you hit 180HP and it lasts 50k.
You should already know but in case you forgot little baby ROLL PINS in the lower oil control ring groove are a requirement on the KBs.
friethmiller
QUOTE(Ninja @ Aug 30 2026, 09:27 PM) *
Yes, you know I know this biggrin.gif . The new rings should be correct but I will verify when they show up. I think these come with a full 360 degree bottom oil ring with a detent that prevents rotation. We'll see.
Jack Standz
QUOTE(Ninja @ Aug 31 2026, 09:27 AM) *
agree.gif Although, there was a time when getting 180 HPs from a type iv was a dream. The original 914/6 put out a "whopping" 110 HPs. Our 2 liter 4 cylinder motor meets/exceeds that.
No doubt that you will enjoy 150+ aircooled HPs in this 914.
As for being 2 thousandths difference between the decks, that's not an issue. A much bigger issue is air getting into the motor in a synchronized/balanced manner (which is why we're considering developing a plenum with a single throttle body/aftermarket FI) even though we already have a new dual throttle body intake system. But, if you've already settled where you're heading with the intake system, you'll be fine.
Very much enjoy watching your project(s) and your careful design and build. Go Fred!!
BTW The Type IV Store has some blanchard ground spacers in stock for certain thicknesses. They should (used to) sell custom sizes? Not sure what the lead time might be if they still offer them.
Ninja
I remember finding a source for custom ground stuff. Long lead time, a little expensive but it looked like they were "retiring" or ending the business.
This was 2 years back. I did buy a set of extended length head studs as I figured I might need them...
LN looks like one of the few good sources left.
Just a bit pricey for my taste.
The T4 cost per horsepower is higher than almost anything else nowadays.
911 horsepower/dollar is not a good ratio either...
friethmiller
Good input guys. Thanks.
If I run .040" shims + either a .010" or a .08" shim (that I found this morning in my a box of engine components), I can now get a deck height of .046 on both sides of the engine. cheer.gif That puts me at a CR of 9.2. One shim is best, I know, but I'd rather have equal deck height running two shims.
I'm set to clay the piston/valve clearance this evening, if I can cut down my adjustable push-rod. The clay is already in the #1 cylinder and torqued down ready to go.
It's basically round the clock engine building whenever I'm not working to pay the bills. blink.gif
Ninja
Make sure the shim packs are exactly the same on adjoining cylinders.
You can have different sizes across the engine but must be the same for both cylinders on one bank.
You can have trouble sealing jug to head is they are different on one bank.
friethmiller
QUOTE(Ninja @ Aug 31 2026, 02:25 PM) *
Yes, I've got a total of .050" on the 1&2 bank, and .048" on the other.
930cabman
QUOTE(Ninja @ Aug 31 2026, 01:25 PM) *
A recent 2056 build I used small strips of Plasti Gage at quarter points at the top of the cylinders when I did a trial cylinder head fit to compare how true the sealing surface ( cylinder to head) connection was. It gave me good information, bolted everything up without a gasket and 20k miles later she is still running great.
friethmiller
QUOTE(930cabman @ Aug 31 2026, 02:31 PM) *
930cabman
QUOTE(friethmiller @ Aug 31 2026, 05:16 PM) *
Cost is near zero, doesn't take much time and provides information
friethmiller
Piston to Valve Clearance (8/31/2026):
Intake Clearance
To do this, I figured I needed to make sure my valve was meeting the spec for the max intake of .507". So, I bolted on a head and used an adjustable pushrod and dial gauge to make the necessary adjustments to hit this number. I wasn't concerned with the valve train geometry, just trying to make sure my valve was opening the required amount. Once that was accomplished, I pulled the head back off and placed clay under the intake valve area on the #1 piston.
I then reattached the head, valve train, and dial gauge. After several rotations of the crank, I pulled the head, cut the clay with a razor, and exposed the profile. With my vernier caliper, I took a measurement of 0.050".
This seems too close for me! chair.gif [ @Ninja mentioned this earlier] I'm thinking this cam and piston combo may not be ideal. I did talk with a rep at AA today. They have liners that are matched with my 2618 JE Pistons with the valve pockets. This might be the better way to go. Hmmmm..... idea.gif
Ninja
"Standard" minimum valve to piston clearance:
Intake .080
Exhaust .100
I'm not certain if Type 4 clearance recommendations are different but there's not a snowballs chance in hell that I'd run what you currently have...
Like I mentioned in my pm one of the KBs shortcomings is it cannot accommodate a serious cam.
A little tiny eyebrow would help BIGTIME on them.
There are "redneck" cutters available for use directly in the head to "cut your own" for many applications (The LS GM engines are one of them).
I have no idea if such a critter is available for VW stuff.
Doesn't really matter. Hypereutectic material is a BITCH to cut (it's the glass that screws everything up) and I would not want to use a hyper cast piston that I'd cut through the outer "skin" on the crown.
Your JEs are beautiful, use them...
Edit: on the "matched" liners...
As Ronald Regan once said "Trust but verify"!
930cabman
I'd play it safe
friethmiller
QUOTE(930cabman @ Sep 1 2026, 07:52 PM) *
I'd play it safe
Yep!
I ordered new liners that should match my JE pistons. They'll be here in a few days. In the meantime, I started moving on the GA block for the LE. I'll post my work on that engine on the other thread.
