Full Version: 915 transaxle into 914-6 questions
Pages: 1, 2
ConeDodger
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so…
What do I need? Currently running the JWest shifter for the 901.
Steve
QUOTE(ConeDodger @ Oct 23 2026, 08:19 AM) *
Been there done that...
I reached out to JWest and converted my 901 Rennshift to a 915 Rennshift. I originally made my own shift rod with two Apex joints. PMS said it was too wimpy, so I ended up with their shift rod. I am running the Martin Bott 916 kit. If your kit is a wevo, it is a totally different animal. It is a lot of work but worth it.
Check out this link for pictures of the home made shift rods. Otherwise pay the bucks and buy all the plug and play stuff from PMS.
http://www.914world.com/bbs2/index.php?showtopic=102988
This page is from one of the PMS builds, mine is identical, except for MSDS 1 3/4" headers for my 3.6.
https://patrickmotorsports.com/blogs/news/1972-914-tangerine
Many moons ago i helped Brad adding a custom cable shift solution to a 915 in a 914.
It worked surprisingly well and costs a fraction of the side-shift kits available.
I have a 915 that was meant to go with the 3.6L engine but i never got around using it.
The plan was to do the same thing and go cable shift.
I’m building two Martin Bott 916 kits right now. I figured I’d get to the shift rod issue when I get done the trans.
I need to sell my 915 with the Wevo kit.
ConeDodger
QUOTE(SirAndy @ Oct 23 2026, 12:12 PM) *
Weird to think that there are maybe only a handful of us that know who you mean when you say you helped “Brad.” rolleyes.gif
Our plan (Mark) was a cable shifter set up. Glad to hear it worked well.
Steve
I am happy with my 915/916 conversion. It also has the cool 916 history to it, but money wise it seems a Boxster S or Cayman S six speed would make more sense.
The 915 is a little balky to shift, but you get used to it.
https://forums.pelicanparts.com/porsche-911...ed-engines.html
Luke M
QUOTE(Steve @ Oct 23 2026, 09:04 AM) *
I have the same setup as Steve. Carrera 915 with the Bott 916 kit and all of the PMS shift linkage. I'm going to use the JWest shifter as well. All still waiting to get installed so no real world experience on how it all works. PMS did the Bott 916 conversion several years ago. It was not cheap then so I can't imagine what it would cost today.
QUOTE(Luke M @ Oct 23 2026, 01:49 PM) *
The kit cost $5500-6k depending on which one you need. Add $1k for tarrifs. A core 915 trans is about $4k and then 5-7k to rebuild and install the kit. Another 2k for LSD and $x to install in the car.
QUOTE(mepstein @ Oct 23 2026, 11:54 AM) *
QUOTE(SirAndy @ Oct 23 2026, 03:37 PM) *
Round numbers. I’m probably a bit less. PMS is probably more. There’s no way to do it cheap. Just like when we bought engines years ago for single digits.
I did just buy the Martin Bott kits so they are real world numbers, not just make believe. Martin won’t ship the kit until you send him the core parts from the 915 trans so it’s a bit of a commitment to get started.
QUOTE(mepstein @ Oct 23 2026, 01:01 PM) *
I don't doubt the numbers, just can't believe what this stuff costs these days.
Steve
QUOTE(SirAndy @ Oct 23 2026, 02:30 PM) *
I’m glad I did the 916 trans when I did. I probably have around $10k in my trans. It was awesome to have a matching trans to my 3.2 and even better with the 3.6.
Steve
QUOTE(SirAndy @ Oct 23 2026, 09:12 AM) *
Cable shift is still in business, but I don’t know if anyone still makes the rear mount for a 914.
https://cableshift.com/product/ols/products/porsche-930
I noticed PMS also sells the cable shifters. Curious if they sell the rear mount.
QUOTE(Steve @ Oct 23 2026, 11:45 PM) *
To the best of my knowledge, PMS stopped selling the cable shift for the 915 conversion cars. Years ago I bought one new from a pelican member. Tried it out on a test stand. It was a joke. Sold it. There’s a reason nobody uses them. If anyone here has a working example, I’ll be shocked and surprised.
Steve
QUOTE(mepstein @ Oct 24 2026, 04:40 AM) *
beerchug.gif too funny Mark!! I have been around 914’s since the late 70’s and have never seen a cable shift 915. Only wevo, velios and factory 916 or factory 916 replica.. Vellios past away and too small of a market for wevo to make new molds, so that leaves the 916 kit by either Martin Bott or the other firm in Switzerland. I thought they were the UK, but the link says Switzerland.
https://www.elevenparts.com/viewer.php?id=8...es/880/elevenp0
I had the cable shifter and a PMS tubular transmission mount. It wasn’t even close to working so I ditched it all.
Maltese Falcon
Jaide Car Co. or very early Rengade also had an adapter mechanism which attached to the tail shifter of the 915 transaxle. I discovered it in my shop racks the other day while re-arranging shop stuff.
Picture coming in a day or two.
Looks like when installed, the mechanism would sit 10" past the license plate blink.gif
QUOTE(Maltese Falcon @ Oct 25 2026, 10:42 AM) *
Jade Car Co. or very early Rengade also had an adapter mechanism which attached to the tail shifter of the 915 transaxle. I discovered it in my shop racks the other day while re-arranging shop stuff.
That was another challenge with the cable shift. I didn’t really want independent mufflers.
The Martin Bott kit is really pricey but if you want the equivalent of a 914 side shift trans, it’s really the best way to go.
I’m custom gearing both the 915 trans in my 67 and my 914. Peter Dawe told me it’s the best performance upgrade you can make on a car. We’ve done it on a couple customers cars and it’s true. It takes the whole driving experience to another level. It doesn’t sound like it should but having the right gear for every shift is amazing.
Steve
QUOTE(mepstein @ Oct 25 2026, 09:17 AM) *
agree.gif I had PMS go through my 916 trans, the previous two well known Porsche shops in so cal, could not figure it out. The car now shifts better than my 901 trans ever did. I just finished my second autocross with it. What a blast with the 3.6. But... I am curious if the Boxster S / Caymen S six speed kit would be a better option now for bigger motors.
QUOTE(Steve @ Oct 25 2026, 12:47 PM) *
I don’t know. I’ve never done one. A buddy of mine does sell a conversion kit to put a 996 trans behind a 3.6. Tyler at top tuning. https://www.topperformancetuning.com/shop
Maltese Falcon
The 20th Century Jaide kit for 915 trans, into the 914.
'Mechanical shift linkage adapter for use with 911 SC/ or Carrera shift console. They also sold the rear 915 to 914 rear undercar bracket to hold 915 into position. I actually saw one on a working /driving 914 at an Aase Motors open house long ago.
Maltese Falcon
...now I'm thinking that the original design for this nosecone shift adapter was from Rod Simpson Hybrids (v8 914/ 911 conversions) in WLA CA. He pre-dated the first Gen Renegade kits. Jaide must have just carbon copied it.
QUOTE(Maltese Falcon @ Oct 25 2026, 04:05 PM) *
I can’t imagine that gave a satisfactory shifting experience. Cool that you still had it in your parts archives.
Maltese Falcon
QUOTE(mepstein @ Oct 25 2026, 02:18 PM) *
I've know a few techs at different independent Air Cooled shops in those days: some of them wrestled with the Velios 915-to-914 shift kits...constantly adjust + re adjust. Adequate gear selection at best.
QUOTE(Maltese Falcon @ Oct 25 2026, 08:58 PM) *
A friend of mine (914dave) has a Velios kit behind his 3.2. I think it works really well for him. But he’s a machinist and told me he did a good amount of custom work on the internals.
East coaster
Is Wevo still a thing? I had a Wevo converted 915 in my 3.6 teener and it worked well with my Renshift shifter.
QUOTE(East coaster @ Oct 25 2026, 09:22 PM) *
Wevo as a company is still in business. They no longer make the 914/915 conversion kit
erwan914
15 years ago, I put together this setup using the original gear lever from a Porsche 914 2.0.
QUOTE(erwan914 @ Oct 25 2026, 11:38 PM) *
That looks interesting!
Krieger
I like that! Maybe with a better cable shifter?
gereed75
Erwan. That looks really slick. Fully adjustable and tightly restrained.
How did it work?
Where there is a will there is a way! Elegant piece of engineering there!
erwan914
QUOTE(gereed75 @ Oct 26 2026, 04:44 PM) *
How did it work?
I had spent a lot of time putting this assembly together, but the results were very successful.
sixnotfour
one Obstacle....no bannana mufflers
sixnotfour
Porsche gearbox Ferrari twin Turb0 308 Custom..
PatrickMS cable shifter.. I made a shifter gate ,,because owner Couldnt find Gears..
In his defense He was racing A Corvette and a AC Cobra a 312 Ferrari... jumping in and out..at the Track.. driving.gif and I converted it to Dry Sump so it had oil pressure while cornering beer.gif
brant
Dang that car looks awesome Jeff!
live free & drive
Cheap solution?
https://www.ebay.com/itm/237142485729?_trkp...c102140.m167418
rgalla9146
I have Martin Bott 916 conversion kit in my GT project on a
magnesium case 1972 915 trans.
I had a friend flip the differential and rebuild the ZF limited slip.
I rebuilt the rest of the trans and located and mounted a bracket inside that is a
necessary part of of the conversion
It as now in my car and working.
I have two issues.
I'm using a 1972 911 shifter which is a 'one year only 'item, it looks the
same as a 914 rear shifter but is quite different in detail to suit the 915 shift pattern.
The linkage between the shifter and trans is similar to a 914 rear shift
and is adjusted in the same way. Adjustment is difficult and is still not perfect.
I supplied the 915 shifter parts Bott needed to modify for the kit.
I also provided the stock 911 speedo drive parts.
My cable driven speedo indicates 50 percent too high. At 50 mph (gps) it indicates
~ 100 mph I've tried different speedos. Same result.
No solution yet, but haven't chased it too much either. Ideas ?
dr914@autoatlanta.com
Martin Bott, in Germany or cable shift, we just listed a 915 cable shift assembly we removed from a car that Jim Patrick built in favor of the Martin Bott kit
914werke
QUOTE(sixnotfour @ Oct 27 2026, 03:49 AM) *
owner Couldnt find Gears..In his defense He was racing A Corvette and a AC Cobra a 312 Ferrari... jumping in and out..at the Track.. Click to view attachment
Luke M
QUOTE(rgalla9146 @ Oct 28 2026, 01:48 PM) *
I have two issues.
Hi Rory,
When PMS did my Bott 915/916 conversion they also installed a sensor for an electric speedo. I'd have to dig through some paperwork to find out what they ended up using. The bracket and sensor mount right on the trans/cv output shaft. Then you'd have to run wires to and from the speedo/sensor. I'll see if I have pics of the bracket and sensor.
Steve
QUOTE(Luke M @ Oct 29 2026, 03:48 AM) *
I have two issues.
Hi Rory,
If the trans is an electronic speedo trans then it should of been part of the flipped differential required for the 914. Wevo makes the side cover for the electronic speedo sensor. https://www.wevo.com/Products/TransmissionP...nSideCovers.htm
I don't miss the bouncy cable speedometer. Easy to wire up to a stock 911 Electronic speedo. I also just used a straight bracket connected to one of the side bolts to prevent the sensor from popping out. I will look for a picture.
Rory’s is a 72. First year use of 915 trans. Mechanical speedo. I’m curious since I’m also building one mechanical, one electronic
rgalla9146
[quote name='Luke M' date='Oct 29 2026, 06:48 AM' post='3276756']
[quote name='rgalla9146' post='3276716' date='Oct 28 2026, 01:48 PM']
I have two issues.
[/quote]
Hi Rory,
[/quote
Hey Steve
Thank you for the offer.
Part of me wants to stick with OEM parts and solve this problem as I've always
done.
I don't know my differential ratio or if the speedo drive parts are correct and
compatable. I didn't think these unknowns would becone an issue.
I'm not too keen on disassembling the trans only to find nothing is wrong and the
problem still exists.
Your solution might be the most sensible way forward.
Any information is appreciated.
Thanks again
Rory
Luke M
Here's what my sensor looks like. The sensor bracket gets mounted to the side cover then wires run from sensor to electric speedo. The wheel gets mounted on the cv.
PMS did not send me any installation instructions so if anyone has some out there that may help too.
scallyk9
[quote name='rgalla9146' date='Oct 29 2026, 03:06 PM' post='3276816']
I have two issues.
[/quote]
Hi Rory,
[/quote
Hey Steve
done.
Thanks again
Rory
[/quote]
Something to check is the final drive ration on your 915 because the early 915 FDRs were different from the later versions.
I have a 1979 915 transaxle (aluminum case) in my 3.2L conversion using the Martin Bott kit. I have a CPS side plate with a standard electronic sensor wired to a 1987 Carrera speedometer and it is very accurate except for a change in tire size.
rgalla9146
[quote name='scallyk9' date='Oct 29 2026, 06:32 PM' post='3276819']
I have two issues.
[/quote]
Hi Rory,
[/quote
Hey Steve
done.
Thanks again
Rory
[/quote]
[/quote]
Hi Scally
What is a CPS side cover ?
By 'standard' electronic sensor do you mean a 911 part ? or an aftermarket sensor
getting a signal from a wheel attached to a CV ?
TIA
Rory
Probably CMS - California Motorsports
https://californiamotorsports.net/products/...llet-side-plate
Steve
I have two issues.
@rgalla9146
Rory,
Curious what motor are you running? Most of the time people switch to the 915 for 3.2 or bigger motors, even though the factory 916's also used the early 7:31 ring & pinion 915 trans with up to 2.9 liter motors (Brutus and the Recaro fire engine 914-6GT), but that's all that was available at the time. The 914/901 trans is also 7:31, so what is the advantage of a 7:31 915? More reliable 1st gear? Better stock gearing? Period correct? Just curious. I know that some 911 owners switch to the earlier 7:31 915 trans because it was better for the track. Lower gears and close ratio shifting.
For me, I went with a 1986 915 8:31 ring & pinion trans for gearing that matched my 3.2. The 914 trans with the 3.2 drove me up the wall, since all the gears were too short for the street and I felt like I was shifting all the time. The later 915 trans also has an electronic speedometer and omega spring. The stock 8:31 Ring & Pinion 915 is awesome with the 3.6. The gears feel a little short compared to the 3.2, but it makes the car very quick. I still plan on changing 5th gear to the tallest 5th which is a TL 29:21 gear. This gear is the same as the stock G50 five speed 5th in a 964. It's also easy to change, since its in the nose cone. You don't have to remove the trans.
sixnotfour
Rory Said...
Martins website says...
In case of mechanical speedo drive we need the OEM speedo drive parts out of your 915 gear cover.
Modifications to gearbox and kit have to be made. Speedometer has to be adjusted.
I have a mech. speedo, mag case.. Kit Too..
and an sc 915 with factory eletronic speedo..
rgalla9146
QUOTE(Steve @ Oct 30 2026, 01:50 PM) *
I have two issues.
@rgalla9146
Rory,
Hey Steve
I went with the 915/916 because I intended to install a bigger 911 engine.
I've been delayed (big time) with what is now a 3.2 short stroke.
To keep the car mobil in the meantime a stock '68 911 2.0 is installed in front of
the 916 !
The 3.2 is almost ready.
My '72 915 most likely has the stock 7:31 ...I never thought to count the teeth
when it was apart .
Based on my experience driving the current combo I know a longer 5th gear is in
my future . 3800 rpm at 70 mph. Maybe other ratios as well.
When I first drove the car with the 916 the speed was obviously way off. I wrote to
Martin Bott but received no reply.
Did Bott say to someone here that a 'speedo adjustment' will be necessary ?
Do you know of anyone with a 916 and an operating mechanical speedo ?
I was told by an instrument specialist thay my speedo error is too great to be
corrected in the instrument.
TIA Rory
Any info from anyone is appreciated. A mechanical solution would be my first choice.
