Full Version: Clutch & throttle cable questions
DC_neun_vierzehn
Last night, I think my throttle cable snapped. I believe it snapped somewhere in the tunnel (bc it's still attached at both ends). Bummer bc I just put it on about 6 months ago. I thought I avoided wrapping it around the clutch cable, but I must not have.
Thus, I thought I would replace both cables "while I'm in there" this time (in case the wrapping/rubbing did any damage to the clutch cable). I thought I read in a post recently that if installing both cables, install the throttle cable first, then the clutch calbe, to help avoid the wrapping issue.
Is that the correct order?
I have a bore scope that I will use and will obviously be more careful this time. Any other helpful tips are welcomed.
BillC
I don't think there's really any order difference. I would just recommend doing them one at a time, which should make it easier to keep the two cables straight.
Also, check your engine ground -- a snapped clutch or throttle cable can often be a sign of a bad ground and the engine grounding through the cable.
DC_neun_vierzehn
QUOTE(BillC @ Nov 2 2026, 08:57 AM) *
Please tell me more. I have no idea what this means.
Are you saying to check the ground strap on the transmission to ensue a tight clean fit?
Shivers
QUOTE(DC_neun_vierzehn @ Nov 2 2026, 07:50 AM) *
Are you saying to check the ground strap on the transmission to ensue a tight clean fit.
What he means is if your grounds, engine and trans are not making good contact at the ground straps that the electricity will follow the least path of resistance. Which can end up your cables. Look at the size of the grounds compared to the size of your cables and imagine the 12 volts running through them instead of the ground straps. They can turn brittle and break sooner than they should.
DC_neun_vierzehn
QUOTE(Shivers @ Nov 2 2026, 10:02 AM) *
Got it. I recently checked all of my grounds and they were good. Will recheck.
DC_neun_vierzehn
Well I dug into the job last night.
Good news: I don’t have to replace my cables).
After removing pedal board I discovered that the threaded ball socket attachment at the end of the throttle cable had simply popped off of the ball where it connects to the pedal assembly.
Before popping it back on, I looked into the tunnel with a scope and noticed the throttle cable was wrapped around the clutch cable. I got that addressed and then reattached the ball socket.
So here’s my question: would the wrapping cause the ball socket to pop off (6 months after installing the throttle cable)?
Or can the metal on the ball socket open up a little after 50 years, and lead to a loose fit that’s prone to popping off? Has anybody had this problem?
DC_neun_vierzehn
Duplicate post
DC_neun_vierzehn
Do the ball sockets attachments at the end of the throttle cable wear out and lead to occasional pop outs?
BillC
QUOTE(DC_neun_vierzehn @ Nov 5 2026, 10:54 AM) *
Yes, if you have the kind of socket that has a little circumferential spring inside the opening of the socket cup -- that little circular spring can loose tension and the socket pops off easily.
I prefer the socket version that uses an external retainer spring that slides into two holes in the socket and then clips around the socket shaft. This version generally won't pop off unless there is significant damage to the cup or retainer.
And, if you don't have a retainer spring, either kind, the socket won't stay on at all.
QUOTE(DC_neun_vierzehn @ Nov 4 2026, 02:05 PM) *
Generally, if your throttle cable is wrapped around the clutch cable, you'll know because your gas pedal will want to move whenever you press or release the clutch.
I think it's more likely that your throttle cable wrapped itself around the clutch cable after the worn socket popped loose.
DC_neun_vierzehn
QUOTE(BillC @ Nov 5 2026, 11:53 AM) *
@BillC
Rut-ro. I didn't see any sort of springs on this ball socket. Can you share pics of either version so I know what's missing?
These pics are not my car, but this is the ball socket I'm talking about. Where are the springs in these pics?
914werke
Make sure the jamb nut is tight to the socket, if it snaps onto the ball positively you will be fine
BillC
QUOTE(DC_neun_vierzehn @ Nov 5 2026, 06:11 PM) *
Those are pics of sockets that have the retaining spring in the hole.
If you look in the hole in the socket (where the ball goes), there will be a groove near the opening. In that groove should be a small circular spring clip. That clip retains the socket on the ball.
If the spring clip is missing, or if it lost tension, the socket can pop off the ball easily. And, it is common for those spring clips to wear and/or lose tension over time, and usually you only get a certain number of times the socket can be popped off the ball before you need to replace the socket.
Here's a (small) pic of the other kind of socket I was talking about:
You can see the retaining spring that fits in a through-hole in the socket and then clips around the shank of the socket. This type seems more secure to me, and more re-usable as well.
Another pic I found: Click to view attachment
