DNHunt
Sep 10 2005, 07:21 AM
Time to hit the garage. Gonna get the car with the new 2270 Raby kit engine on the road.
I need to do the final adjustments to the clutch. Plug a hole in the butterfy in the throttle body with a splash of solder cause it's getting too much air at idle now.
I have 1 big problem, please help. The fan on the CPU in my old laptop crapped so the laptop crashes when it gets hot. MS needs a serial port and the new laptop doesn't have one so I have a PCMIA card with 2 serial ports installed. The laptop recognizes them but they won't connect to Megasquirt. As far as I can tell the port settings are the sames as with the old laptop. Any suggestions? Kevin suggested ice under the old laptop. I thought that was pretty clever.
Thanks
Dave
3liter914-6
Sep 10 2005, 07:33 AM
It'll cost you a few $$, but any of the big box electronic stores should have a USB serial adapter. Usually around $17 or $18, and they work great with megasquirt. Your com port is going to be 6 7 or 8 in that range.
You could also get a couple of bottles of the compressed air for blowing out electronic components, I use that sometime and it really cools things down. Maybe a shot or two every few minutes?
You could also just buy a $5 fan at walmart, plug it into a inverter if you've got one, and rest your laptop on top.
I'm not a PC guru, so I can't really help you with your PCI issues. If you've run through all the available com ports, I don't know what more to suggest.
Bleyseng
Sep 10 2005, 07:54 AM
Fry's has tons of puter parts like the USB to serial adapter cards plus tons of little fans.
They are outside of Renton by 405.
I will call you later on as we are coming down to Gig Harbor today
rhodyguy
Sep 10 2005, 07:55 AM
dave, i was looking at my d-jet tb. the spring loaded screw on the side, air bybass?, is blocked at the plenum. couldn't you drill a hole in the plenum, and adjust/add idle air via that method? are you ready for me to come over? start the turbo barista please.
k
Bleyseng
Sep 10 2005, 08:09 AM
QUOTE (rhodyguy @ Sep 10 2005, 06:55 AM) |
the spring loaded screw on the side, air bybass?, is blocked at the plenum. \ k |
that should make it interesting to adjust the idle rpms..........
ah, stock aint like that. sounds like a DPO mod cuz of leaky hoses or a vacuum leak they couldnt find.
rhodyguy
Sep 10 2005, 08:16 AM
i think this is about as stock as it can be. there is no hole in the plenum that corresponds with the passageway that runs from above the butterfly to the bottom of the mounting surface. intially dave said he needed more air at idle and then the hole he drilled was too big.
k
Bleyseng
Sep 10 2005, 08:21 AM
73 TB, Yep.
I was refering to your refering of the blocked airbypass screw passage at the plenum.
I have seen TB's with the hole or without.
DNHunt
Sep 10 2005, 08:37 AM
Kevin
The air passage through the adjustment screw makes an obtuse angle. In order to accomplish this they had to drill 2 holes. The first hole goes all the way thru to the plenum and is blocked by the gasket and throttle mounting plate on the plenum. The second hole runs from the inside of the throttle body near the bottom of the throttle body up to the adjusting screw. It's really kind of cool.
There that ought to really confuse the issue.
Dave
Bleyseng
Sep 10 2005, 09:26 AM
Kevin,
Take the TB in to get shaft bushings so it won't leak air and has smooth operation. Most old TB's are shot.
Eric Taylor
Sep 10 2005, 11:07 AM
Dave- You can try the usb to serial idea, but you could easily run into the same problem. As the connnection is going through another form of connection it is probably fouling up megasquirt, for today, I think kevin honestly probably has one of the better ideas if you want to get on the road quickly. Making adaptors, including your pcmcia card, work properly can take a lot of time that I wouldn't want to spend when I had a new motor ready to go
. Get a big block of ice and hit the road
Eric
Bleyseng
Sep 10 2005, 11:43 AM
Have Kevin hold one of those battery powered hand fans and aim it at the laptop inlets....
pete-stevers
Sep 10 2005, 11:48 AM
just an Idea.......how bout carbs
J P Stein
Sep 10 2005, 12:18 PM
QUOTE (pete-stevers @ Sep 10 2005, 09:48 AM) |
just an Idea.......how bout carbs |
Nah, carbs are such a PITA....ya gotta have all them complicated tools like screwdrivers & stuff.
DNHunt
Sep 10 2005, 01:58 PM
Up and going. Got the laptop connected. I change some of the port settings. Got a winner. Very little smoke. It sure is loud and angry. Time to buy some more gas and tune some more.
Dave
sixnotfour
Sep 10 2005, 04:33 PM
I tried to help, First thing I noticed it is missing 2 cylinders
Just kiddin went for a ride ,moves out pretty nice, smooth,Great exhaust sound.
Not Stock
Laptop tuning looked very interesting.
No gassy hands ,jet changes, Infintanely adjustable, tune IN and Out in seconds.
Sorry about the Rpumkin Guts I left.
My wife was happy they were gone
effutuo101
Sep 10 2005, 06:28 PM
I would love to see your ride. I recently relocated to Edmonds WA. 206.542.3602 cell 303.807.2757
Bleyseng
Sep 10 2005, 10:16 PM
QUOTE (effutuo101 @ Sep 10 2005, 05:28 PM) |
I would love to see your ride. I recently relocated to Edmonds WA. 206.542.3602 cell 303.807.2757 |
This must be that Chris guy....from the Bay Area and Colorado.
Welcome.
effutuo101
Sep 11 2005, 12:05 AM
yep. Angela is out of town, so I figured I woudl find something fun to do! If anybody has anything going on tomorrow, give me a ring!
C~
DNHunt
Sep 11 2005, 09:03 AM
I changed the oil this morning and adjusted the valves so, I'm ready for another round of tuning. I'm not seeing any smoke this time around so I think it's a keeper.
Anyone who wants to stop by, I'll be around all day after about 10. # 253 851-6447. Here's a
Map Expand the map 1 click for a better view. When you get on 38th St (our drive) Go left, right, left at the 3 Ts.
Dave
rhodyguy
Sep 11 2005, 11:20 AM
lots of zip. i think the cam starts working around 4.2k. this engine wants to wind out. dave thinks the stockish f.i. components will be the limiting factor. time for one of those dual tb setups from the type4 store. start selling some of those 2.0 heads, cranks, rods...ease the pain.
i had never seen the how the mega squirt system is tuned under operating conditions. pretty interesting.
k
