johnmhudson111
Sep 10 2005, 03:46 PM
I was attempting to bleed the brakes on my car today when I notice a stream of brake fluid flowing out of the left front caplier, these are the used 911 "A" capliers I bought to convert over to 5 bolt set up.
Question is this, is it worth the trouble to rebuild the caplier or better to get a rebuilt caplier? I have found them at Vertex for $98 after core charge.
Second question, do I need to replace them as a pair or just replace the one that failed?
ABC914
Sep 10 2005, 04:03 PM
I'm no expert, but I'd check to see what's leaking. If it's the seal around the puck, rebuild kits are cheap and should be easy to fix. If the bore and/or puck walls are scored, then it's probably a good idea to chuck it and get another.
johnmhudson111
Sep 12 2005, 07:30 AM
Ended up ordering a set of rebuilt capliers. I figure that it would be better to have a rebuilt one from "professional" rather than me going in there and forgetting something critical.
