The wire from the sender to the gauge has shorted to ground somewhere.
I'm an idiot. Dave Darling, you da man! Rather than take your advise and check my sender wire which is only a year old, I took the gauge out twice, put in a new pressure module and sender. At that time there was nothing left to change except the sender wire, I found it was rubbing on the steering column. Fixed that and tied it off to the side and now the pressure gauge works. Live and learn, I hope.
