fatlando
Sep 12 2005, 11:51 AM
after dropping my motor yesterday, i want to separate the two. My first gear slips out and want to take a look at whats going on.
any ideas on what to look for?
this is my first time.
ArtechnikA
Sep 12 2005, 12:22 PM
no tricks.
Aaron Cox
Sep 12 2005, 12:24 PM
remove the bolts
fatlando
Sep 12 2005, 12:34 PM
QUOTE (Aaron Cox @ Sep 12 2005, 10:24 AM) |
remove the bolts |
THATS JUST WHAT I THOUGHT!! AAAAASSSS! You guys think you're smart cuz you can read!
Thanx
URY914
Sep 12 2005, 12:36 PM
pete-stevers
Sep 12 2005, 12:43 PM
I think.....i am not sure....but .....I think there are four.....Eh?
Cap'n Krusty
Sep 12 2005, 01:04 PM
QUOTE (fatlando @ Sep 12 2005, 10:34 AM) |
QUOTE (Aaron Cox @ Sep 12 2005, 10:24 AM) | remove the bolts :D |
Thanx |
They're not giving you the whole story! You also have to remove the nuts from the lower studs! The Cap'n
Twystd1
Sep 12 2005, 01:19 PM
I had the same problem a couple of years back...
No problem...... Easy Fix...
I had Aaron show his butt crack in the garage at my house.........
The tranny fell off from the laughter..............
Twystd1
Dave_Darling
Sep 12 2005, 03:23 PM
Only one trick: The through-bolt that holds the starter on. You remove the nut from the engine end of that bolt, instead of unscrewing the bolt from the starter side. 'Cause you can't get a socket or wrench on the bolt-head on the starter.
--DD
DrifterJay
Sep 12 2005, 03:30 PM
yes you can
...be creative
lapuwali
Sep 12 2005, 03:40 PM
You can actually completely replace first gear without separating the gearbox from the engine. Indeed, you can completely remove the gear stack w/o separating them. If you just pull the rear cover, reverse and first are right there. You can even do this with the engine and gearbox in the car...
