Tobra
Sep 13 2005, 01:48 PM
Would one from a VW, well another VW, work?
Like this one, standard beetle or bus for the '70s
bd1308
Sep 13 2005, 01:52 PM
no.
it needs holes on the sides to screw itself to the car...
i had one but it went to 914GT with his wiring harness.
Aaron Cox
Sep 13 2005, 01:57 PM
Jwest makes a bitchin fuse panel replacement
914GT
Sep 13 2005, 01:59 PM
I still have it by the way.
bd1308
Sep 13 2005, 02:03 PM
QUOTE (914GT @ Sep 13 2005, 01:59 PM) |
I still have it by the way. |
did it work out for you....I didn't see the masking tape marking what each and everything went to....sorry about that, I would have re-wrote what was on the tape...
Tobra
Sep 13 2005, 02:37 PM
I don't need one now, I was just wondering. I am lookin to the future, when all the unobtainium the car is made of will require a soul transplant. I figure a lot of the electrical problems people talk about are just corroded contacts, higher resistance, leads to heat, and then to
scottb
Sep 13 2005, 02:45 PM
QUOTE (Aaron Cox @ Sep 13 2005, 02:57 PM) |
Jwest makes a bitchin fuse panel replacement |
yepper....
put one in my car and it works great. extra slots too for adding on stuff in the future.....
why try and rig something when a modern fuse block is already available?
lapuwali
Sep 13 2005, 03:38 PM
The bullet-type fuses also suck rocks. Modern ATO blade-type fuses work much better, and don't tend to flake out like the bullet variety usually do.
brownaar
Sep 13 2005, 03:44 PM
Check the resources section, Engman and JWest both make replacements. I have one of Engman's and it is a nice product.
Tobra
Sep 14 2005, 09:15 AM
okay, okay, I can always use the sack of bullet fuses on the bug, since I will almost certainly still be maintaining it too. How much are those things, aobut $75 or so?
