Tonight I bolted it up to the car. This weekend I'll try to fire it off.
I'll post a notice so you can listen for it.
QUOTE (scottb @ Sep 14 2005, 04:45 PM) |
now that is an easy access teener.....! hmmmmm.... suppose that could be taken a couple of ways huh? |
QUOTE (Buzzard1 @ Sep 14 2005, 04:48 PM) |
Looks....uh ....accessible! No yoga positions required! |
QUOTE (J P Stein @ Sep 14 2005, 04:51 PM) |
Is that a wide open intake port I see......tsk,tsk |
QUOTE (URY914 @ Sep 14 2005, 06:59 PM) |
Here is another tip from my engine builder: When running dual valve springs, use some big fat rocker arm shaft studs or the little baby stock ones will pull out of the head. Stock on the left vs big fat on the right. |
QUOTE (Buzzard1 @ Sep 14 2005, 05:02 PM) | ||
But Paul, the part that threads into the head looks the same size. |
QUOTE (Jake Raby @ Sep 14 2005, 05:55 PM) |
Paul, Go fire up that bitch!! |
QUOTE (Jake Raby @ Sep 14 2005, 07:55 PM) | ||
But.... that thread will hold a tremendous amount of tension.... I have used them with triple springs with 500 pounds over the nose and revved to 8K with no sweat.. I use these studs on EVERY engine I build, even those that have single springs.. The weakness in the stockers is those shitty 7mm nuts! I have stripped them clean off the studs and left the rockers laying on the floor of the dyno room. Paul, Go fire up that bitch!! |
QUOTE (Buzzard1 @ Sep 14 2005, 06:20 PM) |
he said that the studs pull out of the head. |
QUOTE (URY914 @ Sep 14 2005, 08:35 PM) | ||
I did and I was wrong. Jake set me stright. |
