billd
Sep 16 2005, 08:45 AM
I started out to restore my 73 2.0L to its original D-Jetronic fuel injection. At some point I decided that I while I was working on the fuel system I might as well replace the plastic lines with stainless steel and relocate the pump. Here are some pictures with commentary of the fuel line upgrade.
Overall the fuel line install was fairly easy. It would have been much easier if I hadn't decided to run one solid line from the tank all the way to by the MPS sensor. If I did this over again I would do everything the same except that the solid lines would stop at the right side of the firewall and I'd run hose from there.
First, I removed the interior and pulled the fuel tank. Here is a photo of the tank halfway out. The hoses on the tank were long enough that I didn't need to disconnect them through the service hole below the tank. I was able to lift the tank to this position and then disconnect the hoses from above. The new hoses I installed are also long enough to permit access from above.
billd
Sep 16 2005, 08:52 AM
Here is a view of the old lines beneath the tank. The old lines come out of a rubber block that connects with the front part of the tunnel. They stick out a few inches.
There is some surface rust under the tank. I cleaned this up with sandpaper and primed it with Zinc-Chromate before installing the new lines.
billd
Sep 16 2005, 08:57 AM
After the tank was out I pushed the lines back through the block and then went back to the engine compartment, disconnected everything, and pulled. The lines came out easily. I haven't got a clue how you would put plastic lines back in. It would be like pushing a wet noodle up the tunnel.
Here are the lines out of the car. They are steel for the first foot or so and then plastic. The plastic was in pretty good shape but I am still happy I replaced them.
There is a ~30 degree bend about xix inches from the end. The new lines go in much easier if you make this bend *before* you stick them down the tunnel.
billd
Sep 16 2005, 08:58 AM
Another view of the old lines showing the bend near the end.
billd
Sep 16 2005, 09:05 AM
After the old lines are out its time to put the new lines in. I used 5/16 stainless steel tubing - available from Summit Racing. It comes in a 20 foot length all coiled up. What a pain. I would much rather have started with a straight piece. Also 5/16 inch steel brake line would work fine here. The stainless is nice, but the chance of corrosion in the tunnel is minimal.
I put the 30 degree bend in the line before inserting it in the tunnel. Then I test fit the line to mark where the 90-degree bend (actually about a 110 degree bend followed by a 20 degree bend the other way) at the firewall should be. Then I put the line back through the tunnel. Inserting the lines in the tunnel is fairly easy. You just need to make sure you miss the harness that is right on the other side of the firewall.
I reused the original grommets which were in good condition. The small one was a tight fit. The large one needed some RTV to make it snug on the 5/16 line.
Here's a picture with one line in and the other on the way.
billd
Sep 16 2005, 09:08 AM
The lines are run along the firewall and held in place with Adel clamps. I'm probably paranoid, but I don't want them vibrating around and work hardening.
The lines make a 90 degree bend above the heater hose. If I were to do it again I'd stop the hard lines there. Most of the time was spent making the bends after this point and working the lines up through the tin. There is little to be gained by running hard line for the last two feet and that run would be much easier with hose.
billd
Sep 16 2005, 09:11 AM
Here are the lines running along the right side of the engine compartment. The come up through the original grommets, right under the MPS.
billd
Sep 16 2005, 09:12 AM
With the picture this time.
billd
Sep 16 2005, 09:16 AM
Meanwhile back under the gas tank, I fabricated a steel bracket to hold the lines. This is probably not needed. In retrospect the rubber block should do an adequate job of keeping the lines from vibrating.
If you do make a bracket, be careful drilling holes here. There is a brake line on the other side of this panel.
goose2
Sep 16 2005, 09:33 AM
Good thread, thanks! I'll be doing this soon.
Allan
Sep 16 2005, 09:38 AM
You need to replace those clamps with real FI hardware.
J P Stein
Sep 16 2005, 09:50 AM
How are you clamping the lines in the tunnel?
billd
Sep 16 2005, 10:01 AM
The lines are not clamped in the tunnel. They are held at the rear of the tunnel by grommets and at the front by the rubber block. They should be OK without clamps unless some kind of resonance causes them to vibrate in the tunnel.
goose2
Sep 16 2005, 10:13 AM
QUOTE |
You need to replace those clamps with real FI hardware |
So what is the issue with the clamps? I've heard many time that you shouldn't use worm screw type clamps on fuel hoses because they may cut into the rubber. Has anyone actually seen this happen or is it another auto myth? I've been using them for 35 years with no problems on low pressure applications like this one.
Allan
Sep 16 2005, 10:28 AM
From what I've seen, it's the edges of the clamp. Regular hose clamps have sharp edges where FI clamps are curled up. I have seen old FI hose that was cracked and cut at the clamp.
Grimstead
Sep 16 2005, 10:40 AM
Great job
This is one my list before I put the engine back in and your thread is going to help alot.
Thanks!
jsteele22
Sep 16 2005, 11:06 AM
Great job, thanks for the post. I have a couple of questions.
1) Just to be sure : Did you do the whole job w/ the engine in the car ?
2) When you are pushing the lines in from the rear, how do you manage to get them to come out at the front end of the tunnel ? I haven't done any work in that area, but it sounds like a tough job : like threading a needle from a foot away.
3) What do you use to cut the tubing ? Would a regular (home plumbing style) tubing cutter do the job ? I'm guessing this stuff is too hard for that.
4) Did you use a special beding tool, or just do it by hand ?
Thx,
Jeff
billd
Sep 16 2005, 01:27 PM
QUOTE (jsteele22 @ Sep 16 2005, 09:06 AM) |
Thx, Jeff |
1. Yes. The whole job was done with the engine in the car. Except for the last two feet of the run the Engine doesn't really get in the way. If I were to do it again I would not do these last few feet with hard line.
2. You push the lines in from the rear until they hit the front of the tunnel. You then go into the passenger compartment and start the end of the line into the rubber block working through the access panel at the front of the tunnel. Once the tubes are started into the block you go back to the back and push them through until you have enough tube sticking out.
3. I used a regular tubing cutter. Its got a blade that is harder than stainless.
4. I used a tubing bender. You can probably do large radius bends by hand but its hard to do a small radius bend by hand without buckling the tube.
billd
Sep 16 2005, 01:28 PM
QUOTE (Headrage @ Sep 16 2005, 08:28 AM) |
From what I've seen, it's the edges of the clamp. Regular hose clamps have sharp edges where FI clamps are curled up. I have seen old FI hose that was cracked and cut at the clamp. |
If I could find T-bolt clamps or clamps with the edges curled up I would use them. Can you folks recommend where to get such clamps - either in the Bay area or via mail order.
Allan
Sep 16 2005, 02:59 PM
I got all of mine at either Autozone or Pep-Boys...
smooth_eddy
Sep 16 2005, 04:57 PM
From your last picture it looks like you used 2 different types of hose under the gas tank. What was the reason? Also, from an old post the ends of the metal fuel line was threaded so the hose gets a good bite. Do you think there is any chance of your connections coming apart? This is my next project. I am glad it can be done with the engine in place. How long did it take including removing and replacing the interior? Thanks, Eddy
billd
Sep 16 2005, 06:44 PM
QUOTE (smooth_eddy @ Sep 16 2005, 02:57 PM) |
From your last picture it looks like you used 2 different types of hose under the gas tank. What was the reason? Also, from an old post the ends of the metal fuel line was threaded so the hose gets a good bite. Do you think there is any chance of your connections coming apart? This is my next project. I am glad it can be done with the engine in place. How long did it take including removing and replacing the interior? Thanks, Eddy |
The lines out of the fuel tank are two very different sizes, so I used different size hose. I used 9mm hose on the line from the tank to the fuel filter, 7mm hose from the return line to the tank. I chose to use 5/16 hose on the line from the pump to the tank. 9mm would have worked as well, but 5/16 was a more snug fit on the 5/16 OD SS line.
To get the hoses to grip on the SS line I notched the SS line with a file and die grinder. About four notches, one every 1/4 inch at about four places around the circumference of the tube. I also degreased the lines with solvent to get them real clean before I slipped the hoses on. I'll keep an eye on them, but I don't think the hoses will come off.
I did this project over a period of several weeks, grabbing an hour here or there as time allowed. A rough guess on time is:
Remove fuel tank, interior, and old lines - 1 hour.
Fit new lines in place - this took me about 3 hours, but if you ended the lines at the right side of the firewall I think you could do it in 1 to 1.5 hours.
Clamp new lines to firewall - 0.5 hour.
Fabricate clamp and clamp lines under tank - this took me about 1 hour, but you could omit this step.
Reinstall fuel tank - 0.5 hours.
Reinstall interior - I haven't done this yet. I'll guess 1.5 hours.
