Tobra
Sep 16 2005, 09:39 AM
So I looked it over, it seems like you have to remove the lens to access the bulbs. I presume the assembly stays in place, and you just take off the lens, but it is not readily evident how to do so. What is the technique? Already searched and got the bulbs needed.
Thanks
Porsche Rescue
Sep 16 2005, 09:43 AM
Remove the large white plastic "nuts" on the inside of the trunk. Carefully remove the lense.
goose2
to remove the lens, unscrew the white plastic knobs on the back of the tail light assembly
aircooledboy
Sep 16 2005, 01:42 PM
But, don't be surprised if some DAPO has previouly sealed the lense to the housing, in which case you are REALLY in for a treat.
BTDT, many times.
djm914-6
Sep 16 2005, 03:07 PM
I don't mean to completely hijack this thread but...
Once the cover is off, what bulbs does one use?
I have a very tiny bulb next to the outside edge that i can't find a match for and even the others are a bugger to match up.
Does anyone have a list of bulbs with todays numbers?
Tobra
Sep 16 2005, 11:05 PM
Right here for bulb numbersSomeone else looked these up, Thanks, BTW.
What to use to seal lens to assembly, or are these seals still available?
