Kerrys914
Aug 4 2003, 11:03 AM
Hey guys I am attempting to get my 914 water tight (if possible).
How water tight can I reasonably expect to get? Do they all leak some? When it rains outside do you guys get worried about your carpet getting soaked?
Right now I have a car cover on it just to keep the inside dry... I really don't want to cover it every time it rains...
Cheers
Kerry
Aug 4 2003, 11:15 AM
nope, all it takes is $$$ ...
need4speed
Aug 4 2003, 11:22 AM
I'd be MUCH more worried about my floor pan rusting out than my carpet getting wet.
Joe Ricard
Aug 4 2003, 11:25 AM
Don't forget a good dource for the front Targa seal. My son went to purchase one from PP and was told not to buy one right now because of the bad manufacturing process used for the parts in stock...
Don't get carpets wet. why? no carpets
POR-15 is great.
J P Stein
Aug 4 2003, 11:48 AM
They only leak when they're moving or standing still.
The 74 & later upper side window seals (attached to the top) help some.
Curvie Roadlover
Aug 4 2003, 02:20 PM
Mine doesn't leak when it rains, but that's only because it stays in the garage when it rains.
Steve
Aug 4 2003, 03:44 PM
Important safety tip: Do not take your 914 through an automatic car wash!!
I thought my 914 was semi leak proof until I took it through an automatic car wash.
And because I'm really stupid I payed extra for the rocker panel spray option.
By the time I got through the car wash I was totally soaked.
The rocker panel spray option was aimed right where the window meets the targa top.
Thank goodness I didn't install the carpets yet.
I felt totally embarassed, laughed all the way home, changed my clothes and cleaned up the mess.
Steve
Anton
Aug 4 2003, 04:04 PM
Two generally overlooked causes:
1. Inside door plastic covers. Either absent or the they came off because the glue has dried up. I went to the local DIY store and bought some home isolation plastic (2 mm thick), cut it to shape with sizzors, and used double sized glue tape to install. My carpets now remain dry after rain (outside the garage, Curvie).
2. Front window. The original double sized glue tape may have dried up in the past 30 years. My front window was completely loose, producing lots of wind noise and rain water on my head! A new windshield, with custom black masking on the edges for better glue adhesion and a "modern look", solved all that.
One often overestimated cause are the seals... Usually you can SEE where they leak. When that is not the case, see the above.
Good luck.
grantsfo
Aug 4 2003, 04:46 PM
I dont drive mine in the rain for fear of spontaneous rust.
Curvie Roadlover
Aug 4 2003, 05:00 PM
QUOTE(grantsfo @ Aug 4 2003, 02:46 PM)
Amen. Part of my ritual before heading out in the teener is to check the Doppler Radar. Today's a "no go"
vortrex
Aug 4 2003, 05:02 PM
I replaced every seal there was, with the "good" ones. adjusted the top and windows the best I could, still leaked!
Bleyseng
Aug 4 2003, 07:22 PM
New seals and adjusting everything made all the difference in the world. No leaks! In Seattle that is a must!
Geoff
Anton
Aug 4 2003, 07:37 PM
Not everybody has the the luxury of Doppler radar.
Amazing...
And wouldn't that take out some of the fun? Sudden rainstorms give me the opportunity to improve my roof-from-trunk-to-targa-time...
Rouser
Aug 4 2003, 07:51 PM
30-something-year-old car + targa top + 30-something-year-old seals + God-induced
torrential downpour (Guy's got a sense of humor) = LEAKS.
Replace all the seals (ka-CHING $$$!), carry a rain parka
or just try not to drive in the wet stuff.
seanery
Aug 4 2003, 07:54 PM
nice beard!
put some #'s on the guys chest and he looks like a convict!
Kerrys914
Aug 4 2003, 08:02 PM
Thanks for the ideas and laughs
I don't have my door panels on yet or the plastic sheet on the doors. May be that will help some.
I guess I'll do/replace what I can afford and just soak up the rest
My next test will be to sit inside the car and have the wife spray the heck out of the car with water. Since there is only one seat and nothing else, I may be able to see the major leaks.??
Cheers
Kerry
Qarl
Aug 4 2003, 08:06 PM
Make sure you have your digital camera with you inside the car and and take a few pictures during your "water test".
Hee hee..
Did you get the two little door handle seals I sent? Maybe that's the cause of all your leaks. Just kidding.
Curvie Roadlover
Aug 4 2003, 08:11 PM
QUOTE(Anton @ Aug 4 2003, 05:37 PM)
Amazing...
Anton, no doppler radar, but
here's a link to the Hi-Rez Europe satelite loop
Anton
Aug 4 2003, 09:33 PM
Nice satellite pics! I will remember to take a peek next time I go for a topless driving session.
Kerrys914
Aug 5 2003, 05:23 AM
Thanks Karl
I am looking for another set now. If I had more parts to buy it wouldn't be such a big deal..The shipping is 5 3 times as much as the parts
The last rain storm we had I had both of the door handles out..I guess that would casue a little leak, hu
I know the sitting insaide the car sounds dumb but what do I have to lose. If I can eliminate one leak it would have been worth it. I do have some photo's planed for you
I still think I am mising some sort of seal on the door. Is there a seal or?? ion top of the door window guide (latch side)? It just doesn't see right the way both sides look.????? The one car I have to look at (3 blocks away) looks the same??
Cheers
Kerry
mr914
Aug 5 2003, 10:13 AM
I keep towels in mine.
In the 17 years that I've had 914's. 6 years as daily drivers, they have all leaked somewhat.
Hardest part to seal is the front of the top seals. the rest can be adjusted out.
