914werke
Sep 16 2005, 09:12 PM
What do you use to seperate a tubo Tie rod from the rack end?
Is it a special tool or something, its like 24mm wide and impossibly narrow
Aaron Cox
Sep 16 2005, 09:19 PM
Turbo Tie rod wrench!!
~1/4 steel laser cut into a wrench...
the usual suspects have them. a MUST HAVE... likr 40 bucks tho
TimT
Sep 16 2005, 09:22 PM
hmmmmm large Water Pump Pliers
shhhhhh dont tell anyone
TravisNeff
Sep 17 2005, 01:49 AM
Fuch buying the correct tool. Spend 5 bucks on the right sized wrench and slim it down with a grinder. Better yet borrow a wrench from your neighbor instead of buying one
McMark
Sep 17 2005, 02:37 AM
With all the metal cutter types on this board, I'm surprised no one is making the 914Club Turbo Tie Rod Wrench.
JFJ914
Sep 17 2005, 09:41 AM
QUOTE (rdauenhauer @ Sep 16 2005, 11:12 PM) |
What do you use to seperate a tubo Tie rod from the rack end? Is it a special tool or something, its like 24mm wide and impossibly narrow |
32mm and less than x6mm
mightyohm
Sep 17 2005, 10:05 AM
Pipe wrench with a rag over the end.
J P Stein
Sep 17 2005, 11:06 AM
QUOTE (TimT @ Sep 16 2005, 07:22 PM) |
shhhhhh dont tell anyone |
Humm....Tim's been in there also.
Tain't pretty but it works
Porsche Rescue
Sep 17 2005, 12:12 PM
I keep hearing that an inexpensive wrench commonly available at bicycle shops does the job.
Porsche Rescue
Sep 17 2005, 12:16 PM
Here is a pic from a current thread on the subject on the Pelican 914 Board.
SpecialK
Sep 17 2005, 12:21 PM
I used a bonney wrench to install mine, but it's been so long ago I don't remember the SAE size that worked. If you can figure it out (metric-to-SAE), I'll see if I have a spare in that size you can have.
Crazyhippy
Sep 17 2005, 01:28 PM
Bicycle shop should have one... 32MM is a fairly common sive for headsets
BJH
LS6/914
Sep 18 2005, 07:53 PM
Rich, I actually have the factory tool for the job. You are welcome to it. Iam actually home for a week between the shop and the railroad, let me know. Off topic where did the lower ball joint socket end up? Larry
914werke
Sep 18 2005, 08:36 PM
Holy crap Larry! Thanks for the offer and it got into the hands of Dave Hunt to relay to you. Since I was having a difficult time getting over to your side of pond. I chk with Dave Im sure its still in his possesion ....If not, I ll replace it straight away
ArtechnikA
Sep 22 2005, 06:44 AM
for you guys that are, or know, 356 or early VW people, the "front spindle bearing" wrench set is 27x32mm. KD makes a cheap (but serviceable) set you can probably find on the pegboard of your local NAPA store.
