qa1142
Sep 18 2005, 07:42 PM
Anyone know the part number?
Any chance this is it? 0580256996
qa1142
Sep 19 2005, 07:34 AM
94teener
Sep 19 2005, 08:13 AM
All 74 and earlier 914-4 cars came with Porsche Part Number
311 906 091 D ...........
The number you have is probably a VW number.
Phil
VARam1500
Sep 19 2005, 10:01 AM
If you are buying a replacement........
I replaced the fuel pump on my '75 1.8 with a pump from Summit. It had the same specs, same size, and was less than half the price. Only difference was the output hose nipple was about 1/16" smaller. It's been working great. I'll tell you more if you're interested.
--Case...
Dave_Darling
Sep 20 2005, 12:54 AM
Factory manual sez:
70-74 == 0 580 463 009
75-76 == 0 580 463 010
Doesn't matter if they're D-jet or L-jet, same pump.
These numbers may have been superceded by now, though. But heck, as long as the pump can deliver 50 PSI and 12.5 gal/hour, it'll work fine.
--DD
VARam1500
Sep 20 2005, 10:32 AM
I think this is the one I'm using:
MSD Ignition Brand fuel pump at Summit RacingAlso, I think it was the big end (inlet) that was a smidge smaller than the orignial instead of the output I said earlier.
--Case...
Cap'n Krusty
Sep 20 2005, 10:42 AM
0 580 256 996 is NOT a good Boschnumber. The 311 906 091 D is the VW/Porsche part number for the early pump. The part you need is 61 316, the new number for the Vanagon, bus, and 75-79 bug. Even if you have an early car, a little replumbing and a new filter will get you on the road, and it's waaaaaaay cheaper than the early (and NLA, for the most part) pump. I would even risk a used one, as they rarely fail. Just don't buy one that's been sitting for a long time. The Cap'n
