Tobra
Sep 19 2005, 08:55 AM
What is the correct color for the front and rear valences on my car. I don't really mind if it is out of a rattle can, just want to pull the front one off, clean them both up, prime, paint and not have to deal with it again.
Dave_Darling
Sep 19 2005, 09:11 AM
Satin black. Wurth underbody schutz is supposed to be the "perfect match" for CW types; most of us don't mind generic-o satin black rattlecan...
--DD
Mark Henry
Sep 19 2005, 09:33 AM
QUOTE |
and not have to deal with it again. |
The rattle can stuff will chip and if you power wash it peel right off. So " not have to deal with it again" maybe a bit of a pipe dream.
Trekkor
Sep 19 2005, 11:33 AM
I use Rustoleum's gloss black lacquer for my rockers and air dams.
I had the rocker professionally prepped and "rocker schutz" applied.
The only place where I'm having problems is on the leading edges where the gravel is blasting the rockers to bare metal. ( sticky tires throw gravel )
KT
rhodyguy
Sep 19 2005, 11:52 AM
krylon semi-flat black. it holds up pretty well.
k
Howard
Sep 19 2005, 12:00 PM
Purists hate this, but for a driver or track car, I really like it. It does not come off ANYTHING so be careful. Mine were a mess.
HerculinerBefore
Howard
Sep 19 2005, 12:01 PM
After. Hides lots of little imperfections.
Aaron Cox
Sep 19 2005, 12:03 PM
damn howard - those rockers were fuglee!
IronHillRestorations
Sep 19 2005, 12:10 PM
Dupli-color semi-gloss black is a good choice for OEM appearance, and is usually easy to find. I mix standard gloss and flat implement enamel to get the low gloss finish I want, and add some hardener, this is for a spray rig though.
As with any painting, the prep work is the key to a good finish and holdout. Wash with soap and water first, clean with Prep-sol or Klix 88 before any sanding. You want to make sure you remove any and all grease, wax, and silicones before you start sanding, or you'll just push that kind of junk all over the part and have problems.
Howard
Sep 19 2005, 12:12 PM
Hey, that was after I ground off the bondo, filled the holes and hammered the crap out of them. This if fuglee..
Tobra
Sep 19 2005, 01:25 PM
Thanks for the replies, idea popped into my head, how about powdercoating? That stuff is pretty bulletproof, and I think it can be done in a semi-glossy finish.
Aaron Cox
Sep 19 2005, 01:31 PM
QUOTE (Tobra @ Sep 19 2005, 12:25 PM) |
Thanks for the replies, idea popped into my head, how about powdercoating? That stuff is pretty bulletproof, and I think it can be done in a semi-glossy finish. |
got an oven that big???
Mike D.
Sep 19 2005, 01:37 PM
I took mine to Pyramid powder coating and got the satin black, looks great...
-Mike D.
Dave_Darling
Sep 19 2005, 02:36 PM
QUOTE (Howard @ Sep 19 2005, 10:00 AM) |
...It does not come off ANYTHING so be careful. .... Herculiner |
You got that right!!!
Never get it on your Hootus....
--DD
Midtowner
Sep 19 2005, 08:35 PM
Hammy
Sep 19 2005, 08:47 PM
I sanded mine down and then put on black rattlecan primer... Then a clear coat sealer over that. It looks better than "okay" and it has yet to chip. Actually it's held up really well
but I'm sure it'd easily chip if you go offroad
But how often do ya do that
Tobra
Sep 19 2005, 09:22 PM
QUOTE (trekkor @ Sep 19 2005, 09:33 AM) |
KT |
Why not put like a little mudflap in front of it, paint the flap with bedliner and clip it onto the front of the rocker, protect the rocker, and the whole car.
Trekkor
Sep 19 2005, 10:15 PM
Mudflaps, eh?
A guy who a/x's his nice 914 regularly, protects all the inner fender surfaces and rocker leading edges with blue tape.
KT
jonwatts
Sep 20 2005, 12:24 AM
SEM Chip Guard will give you the correct look. To apply it properly you want to lob it onto the rockers like you're spraying silly string. Play around with it and you'll get the idea.
Tho I like the herculiner approach, that might be better if you're running shlicks.
