applescotty
Aug 4 2003, 08:34 PM
I need a torque wrench. Read various reccomendations about what to get. Mine will be for home shop use, probably rebuild my engine eventually, work on my other cars, etc. The clicker type seem nice, and easier to use in different orientations (don't have to be able to see the gauge). But, I've heard that they occasionally need to be calibrated. A beam type is maintenance free, and cheaper, but a little harder to use. Any opinions? Types, brands, etc?
TimT
Aug 4 2003, 08:37 PM
Get a 3/8 beam type.. and a 1/2 clicker type....... then your basically good to go
vortrex
Aug 4 2003, 08:38 PM
I have the craftsman "clicker" type. works fine. can't imagine I would need to get it calibrated. I mean, how much does one use a torque wrench anyways and how far off could it get?
scotty
Aug 4 2003, 08:43 PM
Yeah... and a beam type 1/4" that's in inch-pounds
Aaron Cox
Aug 4 2003, 08:45 PM
i have both sizes in clicker craftsman. they work good.
Eric Taylor
Aug 5 2003, 12:56 AM
I'm gona probably be buying one this week to finish off the clutch job. How much does one cost? I've been told the clicker one is the best. I believe they are hydrolic? That's what I was told at least.
Eric
Curvie Roadlover
Aug 5 2003, 05:02 AM
Back it off to "0" torque when not in use and it won't need re-calibrating (at least not as often).
applescotty
Aug 5 2003, 08:18 AM
Thanks for all the advice. FYI, sears is having a sale on their clicker torque wrenches until the 9th. Normally $69, on sale for $49.
Mueller
Aug 5 2003, 09:56 AM
clicker style all the way..........
I've got a 1/4" drive in-lb clicker, 3/8 drive ft-lb and of course everyone should have a 1/2" drive ft-lb clicker tq wrench for thier lug bolts/nuts !!!!
Just remember to do the conversion correct if you are using a ft-lb wrench for a in-lb application...a buddy of mine cracked his transmission case when he cranked a bolt to 25 ft-lb instead of 25 in-lb, LOL
scotty
Aug 5 2003, 12:18 PM
Cool! Where'd you get it?
TheCabinetmaker
Aug 5 2003, 02:06 PM
Keep the clickers in th box it comes in and don't drop it! dropping it will screw the calibration.
