rhodyguy
Sep 20 2005, 08:34 AM
ok. here's the little bastard.
k
rhodyguy
Sep 20 2005, 08:39 AM
misuse of room temperature vulcanizing compound. 10yd penalty and loss of down. after cleaning would i use the same correct sealant that was mentioned in my other running thread?
k
Mark Henry
Sep 20 2005, 08:40 AM
Toss those valve covers in the scrap pile, pop off the heads and post the pics of the guts...I'd like to see if it has ever been rebuilt.
I smell
rhodyguy
Sep 20 2005, 08:41 AM
the guy
really wanted to make sure the rear main seal was not going to leak.
k
rhodyguy
Sep 20 2005, 08:43 AM
anyone know the story behind this little tag on the oil pump? any visual clues as to what flavor of o.p. this is?
k
Mark Henry
Sep 20 2005, 08:45 AM
Melling pump
rhodyguy
Sep 20 2005, 08:54 AM
the elusive, missing, air injection port plug/bolt. all 4 are no where to be found. either stromberg pulled them when he stole my intake manifolds, or they were never installed. the engine tin was filthy, so who knows?
i'll be pulling one head later this am and we'll see what's going on inside. pictures this evening
just saw your reply about the pump before posting this one mark. what the hell should i do? r&r? shit. oh, the valve covers will be turned in for scrap weight. they should be worth 1/2 cup of fuel with any luck.
k
Root_Werks
Bummer Kevin, so that's "THE" engine huh?
CptTripps
Sep 20 2005, 09:00 AM
That tag is to see if the engine overheated... I think it changes color when the engine gets too hot. Helps the warranty people
rhodyguy
Sep 20 2005, 09:02 AM
yep. this is the stinker. i hope the guy selling the fi setup understands this is the "rebuilt, put carbs on it and install in your car" engine stromberg sold me. i don't think he realizes what a piece of work he's in cahoots with and how his association reflects upon HIM!!
k
rhodyguy
Sep 20 2005, 09:08 AM
so you're kidding on that tag. right?
k
Mueller
Sep 20 2005, 09:14 AM
QUOTE (rhodyguy @ Sep 20 2005, 07:54 AM) |
i'll give you $5 plus shipping for those
SLITS
Sep 20 2005, 09:18 AM
QUOTE (rhodyguy @ Sep 20 2005, 08:08 AM) |
k |
Yeh, he's kidding.......a "heat sticker" looks nothing like that...the one's I used had 3 dots that went to black as the temp was reached/exceeded.
It's got to be an ID tag.
rhodyguy
Sep 20 2005, 09:22 AM
fine mike. send me your mailing address. or we can just swap straight across for a set of vented rotors.
. did you want to opt for priority mail? i was considering an ebay sale. including a long, rambling, text of the adventure with
, type4parts.com, etc. ebay is the only venue i can't hammer him at.
steve, how you doing you lurking, fat prick? how are sales these days? cs'er!!
k
Root_Werks
Sep 20 2005, 09:36 AM
How do you really feel K?
That whole situation would really piss me off.
rhodyguy
Sep 20 2005, 09:47 AM
i'm way beyond the pissed off aspect dan. what's done is done and all i can do is make the best of an unfortunate purchase. but
NO ONE is off the hook at this point. funny, when i sealed the deal on the engine it was around the same time you and i were conversing about going to a 6 or having jeff assemble a 4. i wish i hadn't turned the computer that day.
oh well.
k
TROJANMAN
Sep 20 2005, 09:50 AM
how much did this cost you?
rhodyguy
Sep 20 2005, 09:58 AM
what? the replacement flywheel? the gas to drive it to the shipper to get it from tacoma to so cal? the cost to ship it
back to tacoma from so cal? my insurance co-pay for the valium? the faith in a few members who knew what the play was in camarillo, and failed to give me the heads up? additional faith that went poof, when they failed to step forward when this saga started to unfold and they sat on their hands? you will have to be more specific.
a little sideways here. why are throwout bearing so exspensive?
k
Mark Henry
I have a feeling that your heads will have the
optionial spark plug head cracks....we'll see.
I bet there's valve adjuster screws down those smog holes.
The melling pump....remove it and give it the float test.
TROJANMAN
Sep 20 2005, 10:01 AM
without having to dig up old posts:
what did you think you were buying, and what was the initial cost?
rhodyguy
Sep 20 2005, 10:12 AM
it's no secret. $1.9k, as advertised. if you missed the volumes about this engine, here's easy diggin'. type happy, happy , joy, joy, or just onion with rhodyguy as the member in the search. feedback for type4parts at thesamba. that old "73', 2.0 914 for sale" thread that was in the parts classifieds at the bird. i'm "link" challanged.
k
rhodyguy
Sep 20 2005, 10:17 AM
you will have to change # of days for the search dates. any date is the one you should use.
k
rhodyguy
Sep 20 2005, 02:53 PM
went out and pulled a head. these measurements were taken with a small rule that reads in 1/32", all should be considered +- to within a 32nd or 2. bore 3 3/4". intake 1 29/32". exh 1 7/16". metal spacer between cly #1 and head. no spacer on 2.
some hard carbon in the combustion area. i'll probaby take them to Northwest Connecting Rods and have gerry run them through the big, fancy, hot liquid cleaning machine they have. more feekin' money. pictures later tonight.
k
Bleyseng
Sep 20 2005, 02:54 PM
waitin to see whats inside....
so far it looks like a old motor
rhodyguy
Sep 20 2005, 03:38 PM
forgot. double valve springs. you missed the valve sizes geoff.
k
rhodyguy
Sep 22 2005, 06:53 AM
i think there was a little oil control problem.
k
rhodyguy
Sep 22 2005, 06:54 AM
other side. consistant. where would i look for some part/ reference #s on the cly? should there be any? the parting line doesn't give me any clues
k
rhodyguy
Sep 22 2005, 06:57 AM
dirty valves. oil carbon plenty. wet.
k
rhodyguy
Sep 22 2005, 06:58 AM
a little closer. off to NWC with these after traffic dies down.
k
rhodyguy
Sep 22 2005, 06:59 AM
springs.
k
rhodyguy
Sep 22 2005, 07:03 AM
helicoils on 5 out 8 studs. not impressed. looks like there were sealing issues at the he to exh port. copper gaskets had obvious signs of leakage at a few points. note how black the surrounding area is.
k
Root_Werks
Sep 22 2005, 07:52 AM
$1900 eh. Ouch K, I hope you are able to get it all back together for a good deal.
rhodyguy
Sep 22 2005, 08:10 AM
it's just a little money dan. at this point i think stromberg is wishing he would have refunded the dough-ray-me. i imagine that 1.9 has multiplied by a few factors due to lost sales and lack of future customers. i think i can get it back together without a whole lot more bleeding.
k
TROJANMAN
Sep 22 2005, 09:46 AM
was this supposed to be a fresh rebuild?
rhodyguy
Sep 22 2005, 09:55 AM
i guess
. first it was 1500 miles, then 3 tanks of gas.
it should have been based on the number of quarts of oil consumed. i have no idea. something i couldn't show... the air injection ports are plugged. way down inside there is what looks like some sort of flat tip screw driver headed plug and some silverish goop around them. are they sealed? is it safe? yes!, no!, very safe!!, not safe!!.
k
TROJANMAN
Sep 22 2005, 10:00 AM
so................
what you're trying to tell us is that
is
a piece of
rhodyguy
Sep 22 2005, 10:07 AM
your call. i'm a trusting guy. you tell me x, i expect x. not y or z. have you read the other threads?
k
TROJANMAN
Sep 22 2005, 10:10 AM
some time ago. i was just trying to refresh my memory w/o having to search them out. that's why i was asking about what condition the engine was supposed to be in. it makes a difference being able to see pictures now, versus what was initially promised. that's all.
Tobra
Sep 22 2005, 10:33 AM
QUOTE (rhodyguy @ Sep 22 2005, 08:07 AM) |
k |
I used to be like that. Now I am like a guy from Missouri, show me.
rhodyguy
Sep 22 2005, 11:32 AM
well, i'm showin' ya!
the camera is gone. i can only handle so much of the engine in one day. the tops of the valve stems are hammered. some more so than others. double springs...too much? misadjusted valves
and too much spring? can stems be spot faced? are the heads ruined? great.
k
Mark Henry
Sep 22 2005, 01:24 PM
48mm X 38mm valves...sorry, junk in my books.
The valves stems are hammered because of no lash caps or swivel foot adjusters were used.
Man you got
by
...But you knew that...
rhodyguy
Sep 22 2005, 02:25 PM
your comments make me feel
soooo much better mark.
k
messix
Sep 22 2005, 03:19 PM
looks like
Kev.
sorry to see it look so bad. any cross hatch left in the cylinders?
long ago i took on the attitude that any used engine is just a core unless its mine and i know what abuse it has had. many engines have run great and are just waiting to gernade and some one is trying to get rid of them for a reason.
so some times i'm sure i have missed out on great engines that some one has sold for a reasonable price that was a very good engine, but if there is no warranty, in my book its just a core.
rhodyguy
Sep 22 2005, 04:57 PM
nope. no cross hatching left. i see your point. but...when you buy an engine that is freshly rebuilt (stated), that is ready for you to "put on your carbs and install in your car", you (or me in this case) expect it to be as advertised. when the build sheet is not provided, as it was promised it would be, you're fucked. when the seller bullshits you, tells you he will refund your money, you get the engine within 40 miles of him, and he informs you "i'm not giving you a nickle" you're double fucked. if it had been advertised as an engine that had seen lots of hours, without any assurances, believe me, i would not have bought it. i had more than one inquiry about selling the engine when this ordeal started. i explained what the play was, and never heard from the people again. outside of this place i stood no chance of being hurt, hassled, etc, and could have dumped it. i opted to be able to show my face, both here and within the 914 community in general. UNLIKE LURKING COWARDS. all you guys who are still all buddied up with stromberg, give him a big hello from me. he still has his pals. guilt by fucking association.
k
k
rhodyguy
Oct 11 2005, 04:55 PM
main bearings are marked 10/std. 10 under on the crank and standard on the case?
k
Aaron Cox
Oct 11 2005, 05:03 PM
QUOTE (rhodyguy @ Oct 11 2005, 03:55 PM) |
k |
has the case been align bored?
rhodyguy
Oct 11 2005, 05:16 PM
dunno, check with steve for me would you? that's why i posted the 10/std.
k
MecGen
Oct 11 2005, 05:21 PM
Hey man
Maybe its not so bad.... clean everything up and see. Maybe he broke a few rings on the way in....
You don't know how I feel for you. I got hit for more then that, 1200$ just at "Stephens Fucked Machining"
Whats this all about..
QUOTE |
the faith in a few members who knew what the play was in camarillo, and failed to give me the heads up |
I must of missed it
Positive Karma coming your way
later
street legal go-kart
Oct 11 2005, 05:45 PM
I read all the previous posts.
Cross hatching on the jug walls from the machining process should last about 2500-3000 miles.
Good quality type 4 overhauls ,even if you use some of the old stuff , should run about $3000-4000 depending on the goal in mind.
Are you listening Jake and/or Bradholio?
The lesson here is that good stuff NEVER NEVER NEVER comes cheap.
Sorry you got hosed , if you want someone to take a look at this pile O stuff , contact Arcane Automotive in Fresno, Ca. and talk to Kevin .
He aint cheap but he will NOT rip you off, his engines build great hp and LAST.
Ask me ,I know, and I punish his stuff. Daily.
JT
rhodyguy
Oct 12 2005, 06:56 AM
dist drive gear. the leading edge is paper thin. folded over to be exact.
k
