Full Version: can you identify this pump?
qa1142
Well, I dont have early or late pump
qa1142
Brad thinks may be volvo?
Please help me
qa1142
PN 0580254996
qa1142
Dave_Darling
Look for part numbers. Bosch numbers will typically start out with "0 280 xxx xxx", or "0 580 xxx xxx". There will usually be a Bosch number on it somewhere, in addition to the carmaker's number.
EDIT: OK, you got those. Gimme a couple'a minutes....
EDIT2: Damn, B's good!! The Bosch catalog says: Volvo, 74 140 series; 75-79 240 series, DL, GL; 76-79 260 series.
--DD
sixnotfour
looks like 73-75 911 CIS also
Powerman
Brads right, Bosch Volvo 240.
qa1142
74 75 VW 1.5L or 1.6L
I'm going to instal the '75 pump and remove the plug
Cap'n Krusty
That's a CIS pump....... Makes a lot of pressure and flow. If you're running that in a D- or L-jet car, you're asking for trouble. It'll be fine in a CIS car. The Cap'n
qa1142
Just replaced with 75/76 914 pump and she runs fine.
Thanks to Premire auto for the pump $73 delivered.
