My heart goes out to you and your family. That living room and bathroom picture look all too familiar. I had four feet of water in my house from Hurricane Ivan last Sept. 16th and had water up to the headliner of my 914. I worked everyday after the storm (along with contractors) until we moved back in the house the last week of January this year.
If you haven't already done so, you need to pull out all of the carpet, clothes, furniture and rip out the interior walls and pull all of the wet insulation out. Spray everything with straight bleach and open all of the windows or turn on the AC if you have it. Later, get the dried out wood treated with a mildew killer by a professional ( I had a borate treatment on mine). YOU DO NOT WANT ANY MILDEW REMAINING!!!
Another lesson learned on the 914 (which I did not have time to look at until after I repaired my house). If you plan on salvaging the transmission you need to get to it right away. Salt water will corrode magnesium, BAD. It ate a hole all the way through the case on mine. Also, salt water got into the transmission apparently through a vent tube. My garage was coated with Swepco green tranny lube after the flood receded. I would flush it with mineral spirits and refill with a cheap lube until you get ready to run it.
Don't get discouraged at all of the damage. Work at it every day. The work will keep your mind occupied and make feel you are making progress, even if it is slow.
Contact your insurance company immediately and stay after them. If they stall on paying, contact your state insurance commision and write your senators and congressmen (cc the insurance company). I hope you had flood insurance on the house. Windstorm insurance does not cover flood damage. If you get help from FEMA, expect all lot of red tape and mindless bureaucrats
(I speak from experience). They send a small check immediately after you register with them. You then have to show receipts for generators and such. If you buy a window A/C to dehumidify the house FEMA will reimburse some of the cost. They will help with rental of a temporary residence but only after you submit contracts, receipts, etc. They can also supply a travel trailer for you to live in. We still have people here a year later living in FEMA trailers.
Keep your chin up.
Contact me if you need any help.
Jim Sterling
Milton, Florida
