Red-Beard
Sep 27 2005, 09:46 PM
There is a local shop on my monday night route which remans CV joints. The machine the joints and install oversize balls. The 914/6 friggen joint is unique. At least 1 of mine has gone bad.
Has anyone tried this?
Gint
Sep 27 2005, 10:04 PM
Nope. Lemme know how it works out?
mikey
Sep 27 2005, 11:06 PM
My -6 CV joints were buggered too. I just replaced them with -4s at the recommendation of Brad and Rich Bontempi at HPH. They said the only difference between a -6 and -4 CV is that the -6 internally has one more spline. The dimensions, strength, outside appearance, etc of the -4 CV are the same as the -6.
Changing ball size sounds like a lot of trouble and expense. If you go that route let us know how much it cost and what the result was. (I still have my worn out -6 CVs that could be redone).
mightyohm
Sep 27 2005, 11:18 PM
mikey - where did you get your -4 joints?
I would like to know the costs of rebuilding also.
Someone should go into business adapting VW CV's for 914's. All it would require is a lathe...
Aaron Cox
Sep 27 2005, 11:19 PM
QUOTE (jkeyzer @ Sep 27 2005, 10:18 PM) |
Someone should go into business adapting VW CV's for 914's. All it would require is a lathe... |
Jeff-
which vw Cv's? and what is turned on the lathe?
Engman
Sep 27 2005, 11:27 PM
Yep - got both seats redone locally for $100 - this was 5 years ago - 12000 miles and they are fine...
M
mikey
Sep 27 2005, 11:52 PM
QUOTE |
I got mine at HPH in Redwood City. Rich Bontempi had just got a bunch of them.
lapuwali
Sep 28 2005, 03:22 PM
Hm. Perhaps buy a set to put on the shelf would be prudent. Did Rich indicate he had a steady supply, or did he just raid some secret NOS stash?
mightyohm
Sep 28 2005, 03:45 PM
QUOTE (mikey @ Sep 27 2005, 09:52 PM) |
QUOTE | mikey - where did you get your -4 joints?
I got mine at HPH in Redwood City. Rich Bontempi had just got a bunch of them. |
New or used?
mightyohm
Sep 28 2005, 03:47 PM
Oh and Aaron. I think they are just VW bug CV's.
Two holes need to be opened up to fit the dowel pins (and have a seat about 1/2" down to keep the dowels from going too far).
The outside edge needs to be turned down a couple mm to fit the gasket.
That is if we are going for a perfect replacement, you can "make things work" with no mods at all. But you know how much we like things to be original!
mikey
Sep 28 2005, 06:22 PM
New.
Don't remember what the cost was. I've heard that they periodically are hard to come by so I grabbed them as soon as they were available.
SLITS
Sep 28 2005, 06:25 PM
The reman people use a dedicated machine to hog out the recesses (built specifically for that purpose) and that is why they use an over size ball. Common practice.............
Red-Beard
Sep 28 2005, 07:13 PM
QUOTE (mikey @ Sep 27 2005, 09:06 PM) |
Changing ball size sounds like a lot of trouble and expense. If you go that route let us know how much it cost and what the result was. (I still have my worn out -6 CVs that could be redone). |
So, are you saying a 4 axel will replace a 6 axel?
mikey
Sep 28 2005, 07:20 PM
Exactly - a -4 axle with -4 CV joints on it will replace a -6 axle with -6 CV joints on it.
However, you can't mix and match axles and CV joints, due to the fact that the -6 CV joint and axle have one more spline than the -4 CV joint and axle
In all other respects (dimensionally) they are the same.
Aaron Cox
Sep 28 2005, 07:25 PM
why didnt porsche have ONE cv for all early 911's and 914's?
one spline difference.....
Cap'n Krusty
Sep 28 2005, 07:44 PM
QUOTE (Aaron Cox @ Sep 28 2005, 05:25 PM) |
one spline difference..... |
Because the axles, like the bodies, the engines, the trannies, and a lot more, were sourced from VW. VW used their CVs, modified, and Porsche used theirs. 911 CVs didn't come from any VW product or project. The Cap'n
kart54
Sep 28 2005, 07:45 PM
Performance Products in the San Fernando Valley sells the complete axle for the 914-4 for $361.95 and the CV joint for $110.95 each. Just looked in my catalogue before writing this. Available now and have been for some time as far as I know. I bought a new pair of complete axles when I bought my car in February of this year.
You can find them at www.automotion.com or call 1 800 423-3173.
I have no affiliation with them, just a satisfied customer.
Randy
mikey
Sep 28 2005, 07:51 PM
QUOTE |
Performance Products in the San Fernando Valley sells the complete axle for the 914-4 for $361.95 and the CV joint for $110.95 each. |
Yipes! That sounds steep! I don't remember exactly how much I paid HPH, but I'm sure it was under $200 for each axle/CV joint unit.
Jeesh, maybe they have gone up that much in the last year due to availability (or lack thereof)
