Guys:
I just spent the last hour in the garage working on the 914, trying to get this friggin' air pump assembly off, so I can replace the belt and I'm not having any luck.
If I can get the 13mm socket with a 3" extension on one of the 3 bolts (it's difficult to see, even when using a mirror), I can't stop the fan from turning when I try to loosen the bolt. I'm assuming CCW is loosening them. I've sprayed (as best I could) with liquid wrench and I'll let them soak for a while.
Anyone know of good (safe) way to stop the fan from turning while trying to loosen these 3 bolts?
I think my Haynes manual shows allen or 12 point bolts, but I have hex-sided bolts on mine.
Any help is appreciated. This is really pissing me off!
Thanks,
Andy...
