Sparky
Aug 7 2003, 07:39 AM
What is the magnesium grade that is used on the '69 S case (2.0L 6cyl)? I need to weld a crack (guess where...) and need to make sure I buy the correct filler material.
Thanks!
Mike D.
'75 914/?
what's the point in owning a 914 without an adventure?
ChrisFoley
Aug 7 2003, 03:53 PM
Mike, I don't know the answer to your question but I do have quite a bit of magnesium filler wire. I have used it to repair transmission cases before so it is probably compatible with your engine case as well.
