brewster
Sep 30 2005, 03:18 PM
I have the 911 SC set up on front, but the rear is stock 714-4 that I've done the 5 bolt thing to. I'd like to upgrade the rear brakes with out spending too much money or doing too much work. Any Ideas?
Allan
Sep 30 2005, 03:22 PM
I'm interested in this as well as I have just procured a '79 SC front end and have the five lug rears. I wanna keep the parking brake...
lapuwali
Sep 30 2005, 03:27 PM
The problem on the rears is the parking/emergency brake. You can fit vented rear rotors using a spacer in the caliper (which will have to be made) and possibly an adapter to space the caliper side-to-side or radially (again, will have to be made).
This will do nothing to solve the imbalance problem front to rear. To do this, you require:
rear calipers with bigger pistons to compensate for the front calipers with bigger pistons you've already installed.
OR
a balance-bar type master cylinder (two master cylinders, actuated by one pedal with a balance bar between them)
The former brings up the parking/emergency brake problem, which can be handled by a complete 911 e-brake setup (lots of work), or a small cable-operated caliper in addition to the hydraulic calipers (a fair amount of work, expensive, and heavy).
The later is quite a bit of work and fairly expensive.
pete-stevers
Sep 30 2005, 04:08 PM
Have you upgraded to a 19mm master?
spacers are exspensive, changing to a 911 rear caliper setup w parking brake even more expensive....
i know i will be roasted for this peice of advice but the siplicity of the rear system is great the way it is, just drill the rears and be done with it....or go and get a vented rear, and figure out the spacing with a new caliper and lose the parking brake...i have option B on my car and every time i park on a hill i am pissed that I don't have the insurance of a parking brake....On my brothers car we did option A i have never heard him complain about his brakes..... and option A is cheap!
Eric Shea has all the diffinitve answers
maybe he will pipe up
Aaron Cox
Sep 30 2005, 04:09 PM
do you need an E brake?
if no - then go wild with caliper options....
If yes -
a few options,
Stock or widened STock fr vented rotors
911 Ebrake, drum style, mod to trailing arm and custom cables
Wilwood spot calipers.... (someone has a one coming to market soon that BOLTS ON and uses stock cables... cant say yet)
make a custom braket and mount a mechanical spotcaliper....
or no ebrake..
BTW - do you have a brake TEE installed?
SLITS
Sep 30 2005, 04:11 PM
I thought the 714-4 came with the biggest rear brakes made
Sep 30 2005, 04:14 PM
QUOTE (SLITS @ Sep 30 2005, 03:11 PM) |
I thought the 714-4 came with the biggest rear brakes made |
nope, that was the 913 !!!
Andy
