Tobra
Oct 1 2005, 07:24 AM
I was driving around yesterday, seeing if I could get the gas light to flash in a corner with 3/4 tank(could not do it) and my tach started to work sort of sporadically. It would not match up to the RPMs, would stick around 1500-2000, then later on it was working again, would this be a loose connection or something? Or maybe a mechanical problem, the little needle hanging up somehow. It did not move when I jiggled the gauge, if that is helpful
ArtechnikA
Oct 1 2005, 07:50 AM
check the connection at the coil - sometimes these wires are only hanging by a thread. sometimes the wires break internally from all the vibration.
you may be able to isolate this by swapping in a spare (friend's...) tach to see if it stays with the car or follows the tach.
bd1308
Oct 1 2005, 12:00 PM
hey check your points too.....
my tach acted just like yours, and it didn't hit me until my car stopped sparking on a major KY interstate....(I-71) at rush-hour....
b
McMark
Oct 1 2005, 12:39 PM
If you wanna drive to Napa, I have a mess of tachs you're welcome to try out.
Tobra
Oct 2 2005, 04:04 PM
A drive to Napa sounds nice actually, I have someone with a few here I could try, but I am putting the ignitor on next weekend, so will be right there, moving the points from the distributor to the trunk. I figured it was something like a loose wire, makes a lot more sense it is in the engine compartment than the dash too.
