What might cause this, oh mighty 914world.com brain trust?
I feel like i'm talking to the Wizard in the wizard of oz. =-)
Thanks,
Roger
QUOTE (rogergrubb @ Oct 1 2005, 03:22 PM) |
What might cause this, oh mighty 914world.com brain trust? I feel like i'm talking to the Wizard in the wizard of oz. =-) Thanks, Roger |
QUOTE (Flat VW @ Oct 1 2005, 04:33 PM) | ||
Mine motor but do not illuminate, must be headlight day..... Fuses seem obvious, (mine are okay, by the way) Roger between the two of us we would have one functioning car! John P.S. Where is James (lapuwali) when he is really needed? |
QUOTE (94teener @ Oct 1 2005, 06:07 PM) |
The usual cause of both headlights refusing to pop up while both lights turn on is a defective Light Switch. Usually, pin 56k burns out. But, to be on the safe side, check for voltage on pin 56k, a gray wire attached there. If there ain't no volts there with the Light Switch pulled all the way out, then either your Light Switch or your Ignition Switch is defective. No fuses are involved. Good luck at it, Phil |
QUOTE (rogergrubb @ Oct 1 2005, 09:24 PM) |
Oh yea, and this looks like the replacement fuse block. |
