As if I don't have enough to worry about just now... I went for a ride last night and found 2 strange things w/ my headlights.
1) When headlights are on, turn signals do not work. If I turn lights off, signals work fine. Emergency flashers work fine either way. All fuses are good.
and the weird one...
2) My left headlight works fine on high or low beam. The right one appears to do the exact opposite ! The (right) high beam points down close, the low beam point far away. Fortunately, it points enough to the right not to blind oncoming drivers. Is this something that can be adjusted ???
TIA,
Jeff
