pete-stevers
Oct 2 2005, 10:55 PM
1-what are the pros for changing to turbo valve covers, does it make it go faster
or do the stock ones clear better
2- how do i know when I need to change the tensioners?,
-there is a small leak from behind the tensioner housing
3- where is a good place to get a rebuild on a alterator
other than that the 3.0 ran like a top, smoked for a while after start, but cleared up after temps increased
thanks
steve
ArtechnikA
Oct 3 2005, 05:47 AM
1 - they're less prone to warp and leak; if yours don't, you'll see little benefit.
2 - chain gets loose and rattles, hopefully before it fails completely giving you an exdpensive 3-cylinder engine
3 - Don Marks
Gint
Oct 3 2005, 06:39 AM
Good goin Steve! The motor is in the car then and not on a stand of some sort?
Qarl
Oct 3 2005, 08:38 AM
Steve,
If you use the turbo valve covers, you will have to machine a portion of the fins to clear the trailing arms.
DNHunt
Oct 3 2005, 08:46 AM
Steve
That's gonna be really cool in your car. I can hardly wait to see it. By the way, good choice!
Dave
Root_Werks
Oct 3 2005, 09:06 AM
Wow! I can't wait to see that engine in that car! Good job!
pete-stevers
Oct 3 2005, 09:16 AM
Gint the motor is in the old crashed 911 parts car i have
4th question were is a good place to get the tensioners?
ArtechnikA
Oct 3 2005, 09:32 AM
QUOTE (pete-stevers @ Oct 3 2005, 11:16 AM) |
4th question were is a good place to get the tensioners? |
any of the usual sources.
Pelican will try real hard to convince you to "upgrade" to Carrera tensioners.
using the latest hydraulic tensioners (which have IIRC a 930 part number) and
*this is important* all the tension arm uprated parts - and tensioner guards - are all you need.
my 2,7 was "upgraded" to Carrera pressure-fed tensioners so i'm kinda stuck with them; i wouldn't have done it on my own, probably...
sixnotfour
Oct 3 2005, 11:36 AM
QUOTE |
1-what are the pros for changing to turbo valve covers, does it make it go faster or do the stock ones clear better |
If you have the late alum. lower covers they will be fine and have no clearance issues.
The early mag ones , Bad
