Aaron Cox
Oct 5 2005, 03:22 PM
redshift
Oct 5 2005, 03:28 PM
Porshinator ffooOonTt! OoOowIiee
!M?
Twystd1
Oct 5 2005, 03:55 PM
Aaron... Thats a whole bunch "O" stuff to collect for a 5 bolt setup...
Aa... What would this setup cost for a regular guy that doesn't have all the connections you have? (I.E. dam near free)
What are the advantages of this setup? Could you please list them?
My memory tells me the following.
1) Stronger CVs. (944?)
2) Factory 5 bolt hubs.
3) What else?
Aaron... me b thinking that many of the folks here are interested in this setup. We have all beeen reading about the differant 5 bolt scenarios for a couple of years.
Do you think this setup is advantagous to the Mueller 5 Bolt set up we sell on the club site?
Thanks for doing the layout for me... Now this setup makes MUCH MORE sense because I can SEE what it is... Nice job Bro....
LaterZzzz,
Twystd1
Dave_Darling
Oct 5 2005, 04:05 PM
How is the stock -4 axle modified in this setup? I thought there was a way to do this without having the axles modified or having ones custom made?
--DD
Aaron Cox
Oct 5 2005, 04:09 PM
QUOTE (Dave_Darling @ Oct 5 2005, 03:05 PM) |
--DD |
clay and andy have done this already...
mueller machined the axles...for andy. IIRC - machine a few mm down so the 944 cv can slide all the way on.
Benefits. 914 cv's are NLA.. 944 Cv's are BIGGER and STRONGER and AVAILBALE ANYWHERE
pricey.....
early 911 hubs 50-100
915 coarse spliners 6 bolt flanges 100-200
silly spacers from clays's mechanic 60
951 stubs 9( ) - 50
Aaron Cox
Oct 5 2005, 04:10 PM
and CLaytonian... mueller/Brad did NOT make 5 lug versions of the billet hubs. that was the point of them... to get big brakes without 5 lug
Twystd1
Oct 5 2005, 04:14 PM
So your thinking about 400 bucks for this setup using old parts and add the cost of a little bit of machining... And this doesn't include the cost of the new 944 Cvs? Correct?
Aaron.. for the average guy. Do you think 500 - 600 bucks would cover it?
Twystd1
(That means I can do it for 200
Aaron Cox
Oct 5 2005, 04:16 PM
you can get NEW 944 axles from flaps as cheap as 120 each side....
echocanyons
Oct 5 2005, 04:24 PM
What is the problem with using 911 axels and CV's?
I have this setup on my project car except I have used the 911 axels and stubs.
Part Pricer
Oct 5 2005, 04:26 PM
QUOTE (Aaron Cox @ Oct 5 2005, 06:16 PM) |
you can get NEW 944 axles from flaps as cheap as 120 each side.... |
What are the 944 axles for? I don't see them in your drawing.
echocanyons
Nevermind, I see the difference mine are the fourbolt 911 flanges, cv's and stubs.
Aaron Cox
Oct 5 2005, 05:07 PM
QUOTE (Part Pricer @ Oct 5 2005, 03:26 PM) |
QUOTE (Aaron Cox @ Oct 5 2005, 06:16 PM) | you can get NEW 944 axles from flaps as cheap as 120 each side.... |
What are the 944 axles for? I don't see them in your drawing. |
the come with NEW cv joints
Part Pricer
Oct 5 2005, 05:16 PM
You better check the prices again. I'll bet that they also have about a $100 core charge.
A-1 Cardone charges dealers about $65 each plus $100 core. (reman)
New axles from GKN Automotive have a dealer cost of $193.75 each - no core
New C.V. Joint Kits from GKN Automotive have a dealer cost of $73.97 each - no core
Twystd1
Oct 5 2005, 05:22 PM
Thanks for the correction on the Brad/Mueller hubs Aaron.
So how much ya think a guy can put this kit together for? Including machining of the 944 axle?
Twystd1
Aaron Cox
Oct 5 2005, 05:26 PM
QUOTE (Twystd1 @ Oct 5 2005, 04:22 PM) |
Twystd1 |
ask andy and clay... theyve done it.
parts list
(2) pre 74 911 hubs
(2) 951 27 spline stubs
(4) pre 86.5 33 spline 944 CV's
(2) 914 axle shafts
(2) Coarse spline 6 bolt outputshafts from early 915
redshift
Oct 5 2005, 06:40 PM
WTG Aaron!!
IN YOUR FACE Paul!!!
M
Aaron Cox
Oct 5 2005, 06:41 PM
QUOTE (redshift @ Oct 5 2005, 05:40 PM) |
WTG Aaron!!
M |
Bleyseng
Oct 5 2005, 07:42 PM
great, more shit to buy to keep up with Miles..............
good thing I gots a stash of 914/4CV's until I can locate all these parts
Oct 5 2005, 07:46 PM
QUOTE (Aaron Cox @ Oct 5 2005, 04:26 PM) |
parts list (2) pre 74 911 hubs (2) 951 27 spline stubs (4) pre 86.5 33 spline 944 CV's (2) 914 axle shafts (2) Coarse spline 6 bolt outputshafts from early 915 |
~$300 bucks for the whole package (all used, of course). that includes drinking muellers sodas and eating his chicken wings while he was machining the axles ....
Andy
Oct 5 2005, 07:53 PM
RON S.
Oct 6 2005, 09:23 AM
QUOTE (Aaron Cox @ Oct 5 2005, 03:26 PM) |
QUOTE (Twystd1 @ Oct 5 2005, 04:22 PM) | Thanks for the correction on the Brad/Mueller hubs Aaron.
Twystd1 |
Aaron,
I did take your info,and went junkyarding,for a ll the above 944 axle hardware.
A local yard sold me both sides w/all the hardware,ie bolts. for $130.00
I turned a pair of 914/4 axles back to compensate for the extra width of the 944 cv.Everything went pretty much lock step,except that I have FINE-Splined 915 hubs on my trans.These I cannot change cause I already have installed a Guard LSD in the trans.
Now I'm in the process of machining an adaptor for the cv to trans flange.8mm bolts on the cv versus 10mm on the flange.Plus,a different bolt circle on each.Ya live & learn.
My only concern,is wether I'll have enough take-up slack in the shaft length to account for the additional 3/8"thickness of the spacer.
If not,I guess I'll have to get axles made anyway.
Other than that,It is a truly bolt on affair.
One note to mention,the 914/4 axles are heat-treated,so I had to use carbide and make very my,and very light passes on the lathe to keep the work piece from hardening any more as I was trying to turn it.
Ron
Mueller
Oct 6 2005, 10:02 AM
QUOTE |
One note to mention,the 914/4 axles are heat-treated,so I had to use carbide and make very my,and very light passes on the lathe to keep the work piece from hardening any more as I was trying to turn it |
yep, I went thru 3 brazed carbide tools on Andys axles, 1st 2 were part of the learning process
I have to turn down one more end tonight
914turboford
Oct 6 2005, 11:35 AM
I did not read this entire thread but here is something I found out. The cv joint from a mercedes w123 chassis (1981, at least) will bolt up to an outer 911 stub axle. That is one part of the setup you can get really cheap. They are pretty beefy. So you can get 911 stub axles, Mercedes w123 outer cv joints, then make a hybrid mercedes/914 axle to go to your inner stock cv joint.
Brian
BTW, a w123 would be a 1977 to 1985 300d, 240d, 300td(wagon, that's where I got mine), 300cd, 280e or 280te.
Oct 6 2005, 12:12 PM
QUOTE (RON S. @ Oct 6 2005, 08:23 AM) |
except that I have FINE-Splined 915 hubs on my trans.These I cannot change cause I already have installed a Guard LSD in the trans. |
then why the spacer? shouldn't those have the same bolt-pattern as the coarse-spline 915 output flanges? in which case yours should bolt right up to the 944 CVs ...
Andy
Aaron Cox
Oct 6 2005, 03:59 PM
QUOTE (SirAndy @ Oct 6 2005, 11:12 AM) |
QUOTE (RON S. @ Oct 6 2005, 08:23 AM) | except that I have FINE-Splined 915 hubs on my trans.These I cannot change cause I already have installed a Guard LSD in the trans. |
Andy |
i think they are bigger..
BTW i got the WRONG 915 coarse splines (4 bolt 2 pin) and they are a visible 10mm or so larger
John
Oct 6 2005, 10:25 PM
I am confused on a couple of points.
1. The 951 stub axles are used for what? If the 944 CV Joints bolt to early (100mm) 915 output flanges, then they should also bolt up to early 911 (up to early 1985) outer stub axles (same diameter and bolt pattern as the 915 output flanges).
2. The 944 CV joints are what diameter (100mm to mate with the early 915 output flanges)?
3. What is the part number for these pre 1986.5 944 CV Joints and where can I buy new ones?
4. Are the CV Joint bolts 8mm or 10mm to use the 944 CV Joints?
I fully understand the need to turn the ends of the 914 axle shafts down so the wider 944 CV Joints can be installed.
Thanks for your help.
John
RON S.
Oct 7 2005, 09:48 AM
QUOTE (SirAndy @ Oct 6 2005, 10:12 AM) |
Andy |
Andy,
The axle assy's from the 944 I lifted from a junkyard are bolted down with 8mm x 1.25 pitch bolts.The axle flanges on my 915 box,witch are fine spline,are 10mm x 1.5 pitch. plus,each is drilled on a different bolt circle.
Nothing I can do to change that except to laser-out and machine an adaptor plate.
I'll try to load an auto cad fil of what I'm doing.
Ron
Aaron Cox
Oct 7 2005, 09:51 AM
951 STUB axles and COARSE spline 915 6 bolt flanges have 6 8mm bolts
915 coarse spline 4 bolt 2 pin AND 915 finesplines have a much larger bolt circle... 10mm or so biger OD...
John
Oct 11 2005, 11:49 PM
On my 1985 915, I have FINE SPLINE output shafts with an 86mm bolt circle (6-bolts, no pins) M8X1.25.
I also have a pair of the older style 915 COARSE Spline Output shafts with the same 86mm bolt circle (6-bolts, no pins) M8X1.25 which fit a 914 trans. The CV Joints that fit these output shafts are 100mm OD. The later model 915 (late 1985 +) apparently had the larger output shafts with M10 bolts.
From Ron's CV adapter plates, I am understanding that he has 944 cv-joints with an 86mm bolt circle (same bolt pattern as the older style 915 output flanges and 911 stub axles like I have (6-bolts, no pins) .
Did anyone have the part numbers for the desired 944 CV joints or where to get them?
Aaron Cox
Oct 12 2005, 09:21 AM
pre 86.5 33 Spline.
anything over 86 is 25 spline and will not work.
Johnman.... want to unload the 915 coarse spline flanges?
