Does anyone know of any books or links on fuel injection vs carbs in a general sense?
Any help would be greatly apreciated.
Thanks!
Andrew
QUOTE (tat2dphreak @ Oct 6 2005, 06:44 AM) |
FI blows but carbs suck... what else? |
QUOTE (dmenche914 @ Oct 6 2005, 08:41 AM) |
Carbs. are compatable with vapor emission standards, My triumph Carb float bowl is vented to the vapor recovery can, and this car runs very very clean per dyno smog tests, it even bet some new cars, and it is 25 years old A good carb book would be one of the Haynes series. They have a book on Webers for instance, and it goes into a lot of detial on theroy and how the carb works. Even my old 1961 VW Bug shop manual has nice cut away drawings of the carb, and how it functions in different operating modes (idle, accel, power etc....) So check out an old VW bently manual (Heck get the one that covers the last Bugs, cause it will have both carb and FI info)(admitatly early FI system on the Bug) There are also good basic books on FI, again I would check the Haynes series of automotive book (look on ebay, sometimes you can find them there for cheap) You should also be able to find stuff on the internet (but I usually prefer books) also this site is a great resource, we have folks that know carb, FI and both, so ask any questions you have. good luck |
QUOTE (Andyrew @ Oct 6 2005, 01:03 PM) |
Thanks all! everything helps! Ranting and raving would be great for "quotes"... lol I appreciate your help Andrew |
QUOTE (jsteele22 @ Oct 6 2005, 01:22 PM) |
... Also, the O2 sensor provides something that is (sort of) lacking in carbed or older FI systems : feedback. |
QUOTE (ArtechnikA @ Oct 6 2005, 07:13 AM) |
carburetors must be vented to the atmosphere - it's how they work. they are therefore incompatible with contemporary emissions control requirements. with today's increasingly volatile fuels, float bowl evaporation is significant. carburetors must restrict intake airflow - they work by creating a pressure differential across a venturii. FI doesn't have venturiis; slidevalve throttle bodies don't present any restriction to the airflow at WOT - not even the edge of the throttle plate and the shaft that carries it. |
QUOTE (andys @ Oct 6 2005, 02:52 PM) | ||
Nit-pick (apologies in advance), and a little input.......... Pump and diaphram carbs do not vent to atmosphere, outside of the discharge jets (nozzles). Carb jets respond to the velocity of the air passing across their orfice. Venturi's are used to boost (or increase) that velocity. A carb can be configured without a venturi. Look at a flat slide dirt bike carb (though you could argue that they have a defacto venturi created by the valve itself, though only at less than WOT). Andys |
QUOTE (lapuwali @ Oct 6 2005, 04:40 PM) |
(the SU and the Stromberg). |
QUOTE (lapuwali @ Oct 6 2005, 03:40 PM) |
Even at WOT, the slide hangs down a little. Also, the needle usually helps a bit in creating the necessary vacuum. The carb throat upstream of the slide is generally never completely smooth, either, but forms something of a venturi shape. Some slide-throttle carbs (certain Dell Ortos spring to mind here) even have a small air dam just upstream of the jet to create extra vacua above the jet. I'm not familiar with the terms "diaphram carbs" or "pump carbs". Any carb with a float bowl, however, needs to vent the float bowl to the atmosphere. It's not the low pressure in the venturi that "sucks" the fuel, isn't the higher atmospheric pressure above the fuel in the float bowl the "pushes" it up through the jet and into the carb throat. If by "diaphram" carb you're referring to carbs that have a slide held by a diaphram, then that's a CV carb, and they most certainly have vented float bowls. CV carbs are used on most street bikes now, and have been used on English cars for decades (the SU and the Stromberg). |
QUOTE (andys @ Oct 6 2005, 04:10 PM) |
A diaphram carb (with or without an integral pump) can be found on things like outboards, chainsaws, racing karts, ultralites, etc. where inverted positions and G forces do not effect their performance. I have designed and built a couple of carbs about 10 years ago. Also dry-sumped some carbs. Fun stuff, but lots of testing and development. Andys |
QUOTE (lapuwali @ Oct 6 2005, 04:43 PM) |
OK, do you mean the diaphram is basically in the float bowl, separating the fuel from the atmosphere? If so, that would neatly solve the problem. I suppose a traditional float simply isn't used, but rather the diaphram is thick enough to set the fuel level... |
