Here is my plan...unless someone can make a better argument.
So I now have my billet front hubs, so I am going to be running M calipers with Pagid orange in front. With SC vented rotors.
For the rear I can either run stock 4 rears or put the stock 4 fronts on the rear. With mid performance or stock pads.
Remove the stock proportioning valve and place a T? or leave proportioning valve?
Parking brake will be removed regardless because of roll bar interference with hand brake mechanism.
Will be running stock 4 bolt Fuchs with "R" rated tires.
So give me your best shots, suggestions etc.
