ok i have a list and am looking to you experienced guys for answers thank you for any and all help you can give!!!! this is a ej20t
1. is anyone using the stock subby ecu and harness? how is it hooked up?? do they run aftermarket guages? can it be spliced into the factory porsche harness?
2. does anyone run Link or Mega Squirt systems? can you recomend a system for me??
3. motor mounts, i need measurements and or a template to make them from.
4. radiator mounting position. and what radiator? what hoses or flex hoses? electric fan mounted i would imagine??
5. i have a air to water intercooler any input on it? will cooling be an issue?
6.charge pipes and exhaust? any input and or pics would be very helpfull or ideas??
7. fuel pump needs which pump should i use??
8. throttle cable??
9. i read somewhere about cutting the oilpan down so it won't be so low? if so what do i do ?? don't want to starve the oil???
10. if i missed anything please add to my list!!
