dlo914
Oct 13 2005, 10:40 PM
hooked up everything on the car, but now im not getting power to certain areas of the car. started probing around w/ a test light. discovered power at the starter, but the car doesnt turn over. probed around the fuse box and discovered the following (view image below). As for the fuse box what are the correct fuses for each accessorie and what does each fuse control? Thanks in advance
McMark
Oct 13 2005, 11:13 PM
Fuses 1,2,3,4 are the high/low beams for left & right. So they'll have power when you turn on the headlights and flip between high and low beams. Looking up the other two now...
McMark
Oct 13 2005, 11:16 PM
8 - Fresh Air Fan, Wipers, Lighter, Horn
9 - Stop, turn, backup lights.
