fiid
Oct 17 2005, 04:31 PM
Hey,
I'm missing one of those little clips that keeps the pin that goes through the ebrake cables from dropping out. Where would one get a replacement...?
TIA,
Fiid.
ArtechnikA
Oct 17 2005, 05:48 PM
it's N.012.645.2 if you decide try at a dealer or Pelican or such.
but i just drill the pin 1/16" and run a loop of safety wire through it (my cars are drivers, not concours contenders, and i always know where the spool of safety wire is...). you could also use a cotter pin.
the factory clip is probabky really quick on the assembly line tho.
fiid
Oct 17 2005, 06:58 PM
I'm trying to keep the car original.
Not really - thanks for the tip - I can't believe I didn't think of drilling it... DOH!
mightyohm
Oct 17 2005, 07:01 PM
there isn't much space to drill there. you'll have a hard time fitting a cotter pin unless it is truly tiny and you are very accurate with the drill bit!
