So I went to adjust my newly rebuilt weber 40's and it was backfiring at anything close to idle. Then I saw some leaves and dust fly around right when it backfired.. So I look down and see a backfire, through a gap in the intake manifold gasket!
It appears that the gasket was made out of a phenolic sort of spacer, with a paper gasket on each side. Well there were several spots where the paper had completely blown out. It's amazing it ran at all!
So anyways, I am getting new gaskets tomorrow, and I ran the intakes on a belt sander to get them flat (they weren't even close).
The question is, did the vacuum leak cause the backfires I saw, or do I have a timing/valvetrain/ignition problem to deal with? (the engine never got a chance to warm up, just a couple minutes of running poorly)
