Aaron Cox
Oct 22 2005, 02:41 PM
Cheap h4's. 55/60w bulbs. not hella...or cibiepretty cheap ~30 shipped with bulbs.
any good? worth trying?
sj914
Oct 22 2005, 02:51 PM
I used those on my last car and they worked fine. The only thing I find an advantage is that I didn't have to through away the whole thing when I replaced the bulb.
Since I didn't have to replace the whole sealed beam assembly, I would just take off the headlight skin to get to the back when it came time to change bulbs.
Aaron Cox
Oct 22 2005, 02:52 PM
QUOTE (sj914 @ Oct 22 2005, 01:51 PM) |
Since I didn't have to replace the whole sealed beam assembly, I would just take off the headlight skin to get to the back when it came time to change bulbs. |
plenty bright?
sj914
Oct 22 2005, 02:55 PM
It doesn't really add any brightness, unless you switch to the newer bulbs like the xenon blue bulbs or the higher wattage units.
Aaron Cox
Oct 22 2005, 05:00 PM
i bought a set, and a pair of 55/100 h4 hella bulbs.
sj914
Oct 23 2005, 02:00 AM
I think you would benefit more on using a higher wattage low beam.
Aaron Cox
Oct 23 2005, 02:57 PM
QUOTE (sj914 @ Oct 23 2005, 01:00 AM) |
I think you would benefit more on using a higher wattage low beam. |
55w is legal.
80 isnt
i have pilot fogs, and probably some cibie oscar fogs soon.
AA
