Bret_Jet
Oct 27 2005, 05:31 PM
Hello - I lost my wiring diagram for the wiper motor in my '75 914 2.0. I installed the wiper assembly and I have 4 spade connectors on the back of the motor, looking at the assembly from the front of the car - 1 horizontal at the top, 1 vertical to the right, left and bottom, and 1 spade connector off to the right by itself, which looks like probably a ground. There are 5 wires with connectors BLU/BLK, BRN (2 brown wires into one connector), BLK, RED/WHT+RED/BLK (2 wires going into one connector), and GRN/WHT.
Please can anyone help by telling me the position as per my description that these wires should be connected? I have the wiring diagram in the Haynes book which is really of no help, at least for me, as it doesn't show which wires go to which connectors. There are no numbers next to the spade connectors.
TIA!
grasshopper
Oct 27 2005, 08:14 PM
the two browns go on the connector off to the side..... I just reinstalled mine today, but it's late, and i dont feel like going back out to the garage, so ill get the rest tomorrow.... LaTeR
Bret_Jet
Oct 28 2005, 01:53 AM
Ahh, Grasshopper - you are a life saver! Thanks. I'll look for your post tomorrow - can't tell you how much I appreciate it as I can't proceed to install the rest of the junk until I connect those wires!
grasshopper
Oct 28 2005, 09:51 AM
ok, Black and blue goes to the top connector, the green and white goes to the connector on the left, the black one goes on the bottom, and the red/white + red/black wires go to the connector on the right. Hope the helps with your project, i'm reinstalling my harness now too, so if you need anything else just email or PM me.
jim_hoyland
Oct 28 2005, 11:01 AM
Do you have an intermittant wiper relay ?
grasshopper
Oct 28 2005, 11:10 AM
are you asking me if i have one, or are you asking him, trying to give him help??
Bret_Jet
Oct 28 2005, 12:09 PM
Awesome Barry - thanks again.
Not sure about intermittent wiper - the car has been apart for several years now and just now getting around to putting all back together. But the wire colors that Grasshopper has and mine are the same so I am going to go with those connections.
Thanks for the help!
