shaggy
Oct 30 2005, 08:40 PM
on the oil filter assemble
the nipple that the filter attaches to
what size and thread is that?
it looks like i just cross threaded
id like to get a die and run it over the nipple and correct those threads
i have to go to school tomorrow morning though and my dad (flatvw) is gonna try to find a die for that
so i kinda need to know the size and thread tonight if at all possible
thanks for all the help so far
-jim
Flat VW
Oct 31 2005, 10:03 AM
For the die size......
John
Demick
Oct 31 2005, 10:07 AM
3/4-16
SLITS
Oct 31 2005, 01:38 PM
See other thread...it's aluminum....have you ever successfully "restored" threads in aluminum (without a timesert or helicoil)?
Just a question............
Flat VW
Oct 31 2005, 01:49 PM
QUOTE (SLITS @ Oct 31 2005, 11:38 AM) |
Just a question............ |
I hate "pointed" questions ...................
John
Flat VW
Oct 31 2005, 01:58 PM
An "outside" helicoil, and then we could get custom made oil filters!
J
bd1308
Oct 31 2005, 02:05 PM
or just nix the stock oil filter setup, tap for some nipples at the same location, run some rubber lines or whatever you want to a bug oil filter setup....seen it done, looks good.
b
ClayPerrine
Oct 31 2005, 02:19 PM
If you dimple the oil cooler next to the bolt head you can get a 1/4 drive 13mm socket over the bolt for the oil filter adapter.
Then remove it and replace it.
BTDT.... But no one will believe that I can do it......
Flat VW
Oct 31 2005, 02:51 PM
QUOTE (ClayPerrine @ Oct 31 2005, 12:19 PM) |
BTDT.... But no one will believe that I can do it...... |
Come over here and prove it Clay!
John
P.S. betcha' can't
ClayPerrine
Oct 31 2005, 02:53 PM
I am back in Fort Worth. Are you going to pay for the plane ticket?
Aaron Cox
Oct 31 2005, 02:57 PM
just drop the motor (1hr)
pull some of the surrounding tin and front cover (20 min)
pull engine bar (10 min)
SWAP out OIL FILTER console ( 20 min)
instalation is the opposite of removal.
AA
bd1308
QUOTE (Flat VW @ Oct 31 2005, 02:51 PM) |
QUOTE (ClayPerrine @ Oct 31 2005, 12:19 PM) | If you dimple the oil cooler next to the bolt head you can get a 1/4 drive 13mm socket over the bolt for the oil filter adapter.
John
P.S. betcha' can't |
if you can get it off John....i'll give you a filter bracket.
b
