yeahmag
Oct 31 2005, 04:13 PM
I managed to find a used core motor from a board member (Thanks again Randy) and it came with what looks to be a 911 Flywheel. What, if anything, do I need to know about this conversion?
The bolts were very difficult to get at (13mm) due to the proximity to the edge. Does this flywheel need a allen head bolt?
Thanks.
-Aaron
Aaron Cox
Oct 31 2005, 04:14 PM
wha???
pictures? this a 4 or a 6?
yeahmag
Oct 31 2005, 04:31 PM
This is on a 2.0 /4. The flywheel appears to be the same size and shape as the /4 (for example, the PP fit my /4 flywheel), but the back edge is rounded (so it would be lighter). I can try and get a picture of it later tonight...
The preivious owner mentioned something about shimms, but wasn't too sure himself.
-Aaron
SLITS
Oct 31 2005, 06:43 PM
The only shims are the three (3), count them three (3) that go between the flywheel and the crankshaft to set the end play............
Cap'n Krusty
Oct 31 2005, 07:43 PM
911 flywheels have SIX bolts on the crankshaft, 914/4s have FIVE bolts. They don't interchange, for reasons that should be obvious. If you are having a hard time getting a socket on the perimeter bolts, which hold the cover in place, it's likely the flywheel is junk becauise it's been cut too far. The Cap'n
TimT
Oct 31 2005, 07:55 PM
QUOTE |
911 flywheels have SIX bolts on the crankshaft |
or Nine or even more....
what year is the engine?
there were a few permutations in 911 flywheels over the years..
yeahmag
Nov 2 2005, 06:10 PM
The engine is a '75. I gave up my practically new 914 flywheel!!! Doh!
I'll try and get a picture tonight.
-Aaron
yeahmag
Nov 3 2005, 10:28 AM
Here's a picture of the flywheel...
yeahmag
Nov 3 2005, 10:29 AM
another...
Mark Henry
Nov 3 2005, 11:43 AM
It's a /4 that's been lightened
It needs a regrind and by the looks of the ground down fly bolts it most likely is to far cut to regrind.
You need a better or new flywheel.
yeahmag
Nov 3 2005, 12:38 PM
Anybody have a good used flywheel?
-Aaron
SLITS
Nov 3 2005, 02:46 PM
Yeh....I should have a couple in Riverside....come to the VegasRacer Dinner at El Torito in Ontario this Saturday Night...I could carry one with me.
