kilo123
Oct 31 2005, 04:55 PM
hi help on bleeding the brakes, couldnt get the brakes to stop properly. is there a sequence on bleeding the brakes.
thx
dlo914
Oct 31 2005, 04:58 PM
QUOTE (kilo123 @ Oct 31 2005, 02:55 PM) |
thx |
look in the Haynes manaul!
Rough_Rider
Oct 31 2005, 05:00 PM
Farthest awau from the master cylinder first, then work your way closer.
So rear right, rear left, front right, front left.
Lots of tricks & tips on the site do a search.
Aaron Cox
Oct 31 2005, 05:04 PM
RR, LR, RF, LR
speedbleeders are your friends!
bd1308
Oct 31 2005, 05:07 PM
and those big tank things taht pressurize the resivour....
dralf aka Al Flesher had one....i must get one. made the job SO easy
Dr. Roger
Oct 31 2005, 05:34 PM
so when should the proportioning valve be bled?
after the rears but before the fronts?
bd1308
Oct 31 2005, 05:39 PM
I believe you bleed that during the rear brake bleeding....
fluid comes through the prop valve.
b
McMark
Oct 31 2005, 06:48 PM
I bleed 1/2 quart through each caliper, then let it sit and bleed a 1/4 quart through each caliper. I use the pressure bleeder. Speedbleeders are WELL worth the cost. Also search for trekkor's thread on using a 10' clear hose to recycle clean fluid.
jnaughton
Oct 31 2005, 07:00 PM
Motive Products power bleeder, the only way to go.
JN
kilo123
Oct 31 2005, 09:14 PM
thanks guys
great help
