DanT
Nov 4 2005, 02:01 PM
I know that Weltmeister 180# springs have a blue stripe of paint on them.
What Weltmeister spring has a silver stripe on it? 140#?
Please help me out so I can figure out what I have.
Thanks
Aaron Cox
Nov 4 2005, 02:09 PM
all my welt springs were labeled.... 180/140/100
do a spring test. get a ruler and a bunch of weight... compress spring one inch with X amount of weight.
X/bs per inch springs
DanT
Nov 4 2005, 02:13 PM
here is what I have
Aaron Cox
Nov 4 2005, 02:18 PM
thet appear to be a linear rate. put 100 lbs on em to see if they give an inch.
im guessing 100's or 140's
ppickerell
Nov 4 2005, 06:41 PM
Dan,
I can calculate rate if you can :
Count the number of turns with the very tip of the wire being "zero"
Measure OD
Measure Wire size
DanT
Nov 4 2005, 06:57 PM
11 turns
don't have calipers but as close as I can tell 13/32" wire diameter
or 11 mm.
spring OD 4.25"
Thanks
Aaron Cox
Nov 4 2005, 07:01 PM
QUOTE (Dan (Almaden Valley) @ Nov 4 2005, 05:57 PM) |
11 turns don't have calipers but as close as I can tell 15/32 OD or 11 mm.
wire size?
Thanks |
your 11mm is wire size....
OD of spring 2.5" 3" etc
ppickerell
Nov 4 2005, 08:11 PM
I can calc from that at work Monday.
Mueller
Nov 4 2005, 11:35 PM
QUOTE (ppickerell @ Nov 4 2005, 07:11 PM) |
I can calc from that at work Monday. |
if you cannot wait till Monday
spring calculator
not sure how accurate it is...I'm sure Patricks calculations come out better since he makes springs...
DanT
Nov 7 2005, 09:39 AM
Demick
Nov 7 2005, 09:57 AM
I'm almost positive that my old Weltmeister 140's has silver paint like that. Newer Weltmeisters are marked with actual numbers (what a concept!).
Demick
DanT
Nov 7 2005, 10:32 AM
That is what I thought....just want to make sure what they are before I try to sell them. Don't want to misrepresent what I have to sell. I have a brand new set(nos) of welts with Blue stirpes on them.
ppickerell
Nov 7 2005, 12:03 PM
Dan,
Using the numbers you gave me I calc under 100#'s assuming chrome silicon wire.
DanT
Nov 7 2005, 12:47 PM
Thanks Patrick.
