davep
Nov 5 2005, 11:56 AM
Here is a set of replacement pads for a 914/6 with the full kit of small parts. Genuine Porsche parts box and ATE Textar pads (TP22). Note the rounded square large pin hole.
davep
Nov 5 2005, 11:57 AM
Regular 914/4 rear pad front face. Note the groove depth tapers. Note the square large hole.
davep
Nov 5 2005, 12:00 PM
The back of the same pad. Note the recess that probably accomplishes much the same as the recess in the front caliper pistons. Not all regular 914/4 pads came like this though. The fact that the pad has the large and small pin holes show it was intended for the 914/4.
davep
Nov 5 2005, 12:01 PM
Please do not wear out your pads like this. The piston had to be replaced, therefore the caliper had to be scrapped due to lack of replacement pistons.
davep
Nov 5 2005, 12:02 PM
The outer adjuster mechanism from a 914/4 piston.
Eric_Shea
Nov 5 2005, 01:12 PM
That piston can be saved
davep
Nov 5 2005, 01:22 PM
Right, where do I send the trash pistons? I only need a half dozen so far. How many have you found so far?
Eric_Shea
Nov 5 2005, 01:34 PM
QUOTE |
How many have you found so far? |
Probably about 1/2 dozen. None as bad as that though. It takes talent to do something like that.
PM me... I created a air tool bit for the pedal shaft removal you were asking about.
