5dogs
Nov 5 2005, 12:45 PM
I have a bad starter. Went to the local auto parts store and had it tested. He then said he had one in stock. I pulled it out of the box for comparison, and it did not look the same. He checked all his numbers and checked different years. All the same. The difference was in the gears/teeth. Mine has a white plug on the end of the gear while the new one has a shaft about 1 1/2 inches long. I don't know if I am describing it right. Hopefully, one of you guys will know what I am talking about. I did not buy the starter buy the way. Any help would be appreciated. thanks.
Dave_Darling
Nov 5 2005, 01:31 PM
It's an error in the parts book. I believe that the one he showed you was for an automatic Bus. The correct part number is SR-17X.
--DD
Always Looking
Nov 5 2005, 10:40 PM
I had the same problem from Kragen in my area. I have a 72 and finally asked to look at the started for the 73. The showed me a totally different starter. On the correct one, the whole shaft slides out of the starter, not just the pinion gear on a shaft. Post or pm if you have more questions. Sorry for the bad description.
scruz914
Nov 5 2005, 11:40 PM
Avoid future hot start problems. Get one of these.
914 starter
