Matt Meyer
Nov 5 2005, 09:34 PM
I was following the bird boards tech article on ignition switch removal. I got down to where I need to remove two screws... But on my 75 it is all one cast piece. What do I do next.
My steering column:
Matt Meyer
Nov 5 2005, 09:35 PM
Bird board pic:
Matt Meyer
Nov 5 2005, 09:36 PM
Another from the other board
bd1308
Nov 5 2005, 09:40 PM
there's a pin on the bottom of the column you have to tap out or something.
I don't know. complete guess. all i know is that there is a pin.
b
eeyore
Nov 6 2005, 09:17 AM
A: on the underside of the steering column housing is a 5mm (6mm?) allen head screw. Remove it. Pull the electrical connectors off the back.
B: Remove this clip
C: No need to remove this clip.
The whole aluminum assembly should now slide off the steering column
D: Separate the plastic cover from the assembly, and remove a small screw at the back of the ignition switch area. The switch should slide out.
NOTE: Use a genuine Porsche part ($40) instead of the $12 aftermarket part.
