qa1142
Nov 6 2005, 11:04 AM
Saw these in the "engine drop party thread"
Where can I get them?
Aaron Cox
Nov 6 2005, 11:05 AM
from the schnorr storr
i think the dealer if all else fails. try mcmaster carr
Allan
Nov 6 2005, 11:09 AM
If you're not in a real hurry, Pelican, GPR, HPH, etc. all have them.
Mueller
Nov 6 2005, 11:12 AM
QUOTE (qa1142 @ Nov 6 2005, 10:04 AM) |
Where can I get them? |
or you should be able to get them from the same person you got all your 2.0 parts from, I'd think Brad would have some in stock
qa1142
Nov 6 2005, 11:14 AM
what size? 7MM or 8MM??
Add this to your quizes Dave
qa1142
Nov 6 2005, 11:37 AM
Ok so I have to answer myself
999 523 102 01 - is 8mm lock washer
100 SS 8mm from McMaster Carr $15
bd1308
Nov 6 2005, 11:47 AM
will i'll buy a few from you if you get the Mcmaster ones.
Trekkor
Nov 6 2005, 12:19 PM
I would think any well stocked hardware store would have them in the "Metric Isle".
KT
Mueller
Nov 6 2005, 12:26 PM
QUOTE (trekkor @ Nov 6 2005, 11:19 AM) |
KT |
i think I've ever seen them at the usual hardware stores....
Flat VW
Nov 6 2005, 12:31 PM
Is this a "loaded washer" , that is to say deformed, not flat?
John
Aaron Cox
Nov 6 2005, 12:33 PM
QUOTE (Flat VW @ Nov 6 2005, 11:31 AM) |
John |
not a spring or a split washer. it has teeth that bit into each surface...
McMark
Nov 6 2005, 01:56 PM
It has teeth, but it is also conical, from what I remember.
Allan
Nov 6 2005, 02:36 PM
1 more. Conical.
jimtab
Nov 6 2005, 03:22 PM
QUOTE (trekkor @ Nov 6 2005, 10:19 AM) |
KT |
Our store certainly does....
shaggy
Nov 6 2005, 11:02 PM
would BAP imports have that kinda thing?
they dont do porsche and have zero 914 crap, but they carry stuff for german cars
do you think they would have it there?
bd1308
Nov 7 2005, 12:59 AM
QUOTE (shaggy @ Nov 6 2005, 11:02 PM) |
do you think they would have it there? |
worth a check, eh?
if they don't well at least you looked....
Hardware stores carry metric stuff......i'd try there, like a true-value or like a home depot (but HD doesnt have jack)
SLITS
Nov 7 2005, 09:58 AM
And what's wrong with Loctite in their place with a normal spring washer?
Flat VW
Nov 7 2005, 10:01 AM
QUOTE (SLITS @ Nov 7 2005, 07:58 AM) |
And what's wrong with Loctite in their place with a normal spring washer? |
Not vintage (old), besides one would not get to go to store and ask for "sleeping washers".
John
SLITS
Nov 7 2005, 10:10 AM
Okeh.................
By the way, I believe Cap'n Krusty has stated a few times that in place of the cheap paper CV washer, RTV works wonders too!
Old heh......
I guess us "backyard arthritic mechanics" do all sorts of bad things
lagunero
Nov 7 2005, 02:36 PM
where are these washers a must?
SLITS
Nov 7 2005, 02:38 PM
QUOTE (lagunero @ Nov 7 2005, 01:36 PM) |
where are these washers a must? |
CV joint bolts (the ones that bolt the cv joints to the flange). They are a style of an "internal lock washer".
I guess I'm unsafe...I use locktite
