qa1142
Nov 6 2005, 11:45 AM
anyone use this on their case?
What do you use where for rebuilds?
Case?
Jugs?
love that word
pushrod tubes?
etc?
Mueller
Nov 6 2005, 12:23 PM
what references are you using for the rebuild?
Jakes video, the Haynes manual, factory manual ?? or ??
qa1142
Nov 6 2005, 12:40 PM
Reference? 30 years of working on cars including a 79 westfaila 2.0L rebuild
Plus I do have Jake's video
Plus air cooled vw manual
Plus hayes
Plus Brad Mayuer
What do you recommend? (or who)
Aaron Cox
Nov 6 2005, 12:43 PM
use the raby vid
Jake Raby
Nov 6 2005, 03:00 PM
I put a lot of effort into the video to cover the things that no manual covers... They don't show you hidden bolts that keep you from destroying your case!
sean_v8_914
Nov 6 2005, 10:01 PM
Jake: is your avatar the face you made when you found the bolt behind teh flywheel?
PS. when is the T-4 HP trick video comming out?
DNHunt
Nov 7 2005, 07:58 AM
I've used it several places. It sets when there is no air in contact with it so you can put it on and let it sit on unassembled parts for a little while. That makes it great for case hardware like washers nuts and bolts.
518 can allow you to seal without a gasket. That makes it great for a lot of appended stuff like cam plug, oil pump, oil filter housing, taco plate but, not the O-ring. Be aware once it's deprived of air it sets up pretty fast and it's a bitch to clean off of parts once it's set. Cleanup of unset stuff is a snap so you can do a real neat job.
Don't try to seal the case with it. It sets up too fast and it will be too thick. I think you will do better with something that doesn't harden. I've heard of Yamabond or Kuril K2 and a few others. I think Shoptalk Forums has a lot on this.
Great stuff.
Dave
KevinP
Nov 7 2005, 08:34 AM
I've been using Yamabond #4 for the last 30 years and found that it works great on case halves. Easy to find and, I think bike cases take alot more vibrations and abuse than our TIV's.
KP
Jake Raby
Nov 7 2005, 08:45 AM
DO NOT USE IT ON THE CASE!!!!!
Doing so will create a bond that will make your case halves virtually inseparable for 1200 hours- Thats what it's designed for in the Aviation world.
Curil K2 is my case sealant of choice...
BTW_ I'm only awaiting the artist to finish his part of my sealants guide, it should only be a few more weeks... I lost 40% of the guide when a power surge killed my entire network, it should have been done by now.
