bd1308
Nov 7 2005, 06:42 PM
okay, I know about the grounding points issue to stopping an engine cold in it's tracks.
but the downside is heating up that coil and having it blow up. I have points now (pertronix would have obvious problems with this).
does anybody know (i cant read wiring diagrams yet) which fuse trace and wire powers the coil? I know its unfused, so I guess I answered my own question...my gut feeling is that the only way to get to it is through the engine bay. But I could in therory put a kill switch in there.....
any thoughts?
b
Aaron Cox
Nov 7 2005, 06:44 PM
you think someone is going to steal your car?
just pull the plug wire off your coil before you leave it
Rider914
Nov 7 2005, 06:46 PM
Switch the fuel pump if it is injected.
bd1308
Nov 7 2005, 06:49 PM
its carb'd.
i could do the fuel pump, give em a hundred feet till the fuel in the bowls runs out.
could unplug the coil.
i dunno. any other ideas?
b
Dr. Roger
Dude,
just run a wire from the neg terminal of the coil to a switch skillfully placed somewhere outof sight. then from the other terminal of the switch grounded to the body.
Walla'.
Suppose you could trace that green power wire from the ignition switch... Or was it black?
scotty b
Nov 7 2005, 06:58 PM
Killswitch?????
ENGAGE!
bd1308
Nov 7 2005, 07:00 PM
QUOTE (rogergrubb @ Nov 7 2005, 06:49 PM) |
Dude,
Walla'.
Suppose you could trace that green power wire from the ignition switch... Or was it black? |
but if the killswitch is engaged and the thief tries to dick with my car, starting and starting it....
the coil heat up and BLAMO! hot oil all over everything.
b
jd74914
Nov 7 2005, 07:06 PM
So, please tell us WHY anyone would want to steal your car?
In any case, a kill switch is just something else to worry about. If you are that worried pull off the coil plug wire like aaron said
bd1308
Nov 7 2005, 07:09 PM
someday my 914 will look good.
b
jd74914
Nov 7 2005, 07:25 PM
joking BTW, but i still don't know why you wouldn't just unplug the coil, easiest to do, and it follows the KISS principle which means it is one less thing to worry about
Aaron Cox
Nov 7 2005, 07:50 PM
QUOTE (jd74914 @ Nov 7 2005, 06:25 PM) |
joking BTW, but i still don't know why you wouldn't just unplug the coil, easiest to do, and it follows the KISS principle which means it is one less thing to worry about |
werd
Mueller
Nov 7 2005, 07:53 PM
the proper use of the kill switch is remove all power from the battery to the rest of the car........
for your application, you could just get a toggle switch and wire it in series with the + of coil....
bd1308
yep.
b
r_towle
Nov 7 2005, 07:57 PM
my race car had a simple 150amp 2000 amp surge kill switch in the negative battery line.
Basic to install, and you could either hide in the engine bay, or put it in the trunk
switchRich
Aaron Cox
"valuable Teener part" Oxymoron
scotty b
Nov 7 2005, 07:58 PM
Why not just take the key out of the ignition??
effutuo101
Nov 7 2005, 08:05 PM
I have a Bosch battery isolation switch on my car. I just moved it from behind the sail into the cab. It is steel and lasts about 1000 times longer then the cheap plastic one at your local parts house. I had one of the original Porsche switches, but it got swiped. If you put in a battery cut off, I believe that you have to cut off the + side of the battery. I moved to a rainy place, and decided to put the switch out of the elements.
Aaron Cox
Nov 7 2005, 08:07 PM
like this chris?
i need one.... eric shea sold 2 for 30 bucks a piece or somehting a year ago.....
this choad wants 120 for it lol
Allan
Nov 7 2005, 08:09 PM
effutuo101
Nov 7 2005, 08:15 PM
That is the one! I just bought a replacement for $70 at European Auto up here in Seattle. Thanks for having the pic handy. I was going to drive over to my sisters and dig the box out of the trash.
Dr. Roger
Nov 7 2005, 11:32 PM
I picked up one of these at my local marine hardware outlet while I was shopping for fuse block replacement.
Even has a removeable key.
I don't know exactly where i'm going to put it yet, but it will probably go inside center console. concealed.
